XBMCZ Gotham 13.0 (Libmedia) - Download
    XBMCZ Gotham 13.0
    New XBMC version libmedia;
    features:
    * Gotham XBMC 13.0 with support libmedia
    * Support DTS, AC3 passthrough SPDIF
    * Best video performance
    Tested on CS968.
    Link:
    http://www.mediafire.com/download/m2...r379/XBMCZ.rar
    https://drive.google.com/file/d/0ByLFi_eiNYgfNVhyRXZETkxiYW8/edit?usp=sharing
    Originally posted by netguto View Post
    XBMCZ Gotham 13.0
    features:
    Tested on CS968.
    Link:
    Your link does not work.
      link working fine for me.
        is this the same as the gotham rc1 that got pulled temporarily from xbmc.org?
          XBMC 13.0 is Officially Release as per May, 4 2014.
          Any different from your release?
            i have cs968 ver.3 6210.
            i tried the official stable gotham rise and i had many drop frames when i passthrough the sound to my home theater.
            ...but this XBMCZ works great !
            ....thanks to netguto
              The official version does not support passthrough dts ac3 in CS968. For it has to use the hack libmedia together with a version of XBMC that supports libmedia hack.
              Thanks.
                Thanks.
                Is yours based on XBMC 13.0 RC1, or XBMC 13.0 Final??
                  It's based on Final version 13.0, but usually working in CS968.
                    Try,
                      Thanks.
                      I see, thanks. Since the v13 final is smooth enough on kitkat, i do hope same as yours. Cheers,
                        Tested it on Cloudnetgo CR11S and working smoothly, no issue yet. I have noticed one issue which not working to well on frodo or gotham or beyond xbmc, is when I tried to exit xbmc, it just sitting there for a long time. If I remembered correctly only the first version of Gotham existed right away when I click "exit", if you have time can you investigate?? For the work around, I installed "adv task killer" to kill xbmc.
                          A suggestion for the next release
                          Hi, Again thank you very much for this xbmcz version, pretty stable fast and smooth. For the next update, please pre-config all the sources like xbmctalk, mashup and xbmc.org. This is very convenience when we do fresh install which most of us preferred. Again Thanks...
                            So far it seems like KitKat + Gotham is the winning combo for now (until flumster Gotham-ups BXBMC..) but..
                            I am have a hell of a time getting any of the usual suspect add ons (1channel, sports devil, ect) to work. all dependency errors...
                            any workrounds/unoffical ports?
                              XBMCZ Gotham 13.0
                              features:
                              Tested on CS968.
                              Link:
                              I need to replace libmedia.so and copy advancedsettings?
