XBMCZ Gotham 13.0 (Libmedia) - Download
Incompatible Addons (fixes)
Originally posted by servo386 View PostI am have a hell of a time getting any of the usual suspect add ons (1channel, sports devil, ect) to work. all dependency errors...
any workrounds/unoffical ports?
How do you edit addon.xml?
The addon.xml file to be edited is in the actual addons folder. Not the repository folder.
To edit them (outside xbmc) you would need to enable view hidden files then navigate to that addons folder
(navi-x as an example)
- Operating system File path
Android /storage/sdcard0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/Navi-X
- Open the Navi-X folder
Open the addon.xml with an editor like notepad, Root Explorer or ES File Explorer
Look for this line:
<import addon="xbmc.python" version="1.0"/>
And change it to:
<import addon="xbmc.python" version="2.1.0"/>
Hope this helps.-Chromecast with Google TV
- Android Q Android 10
Originally posted by edwardckc View PostHi,
I need to replace libmedia.so and copy advancedsettings?
Link CS968 Geass - http://www.freaktab.com/showthread.p...ASS-quot-ver-1
Libmedia attachedAttached Files
Originally posted by TomThumb View PostExactly which firmware are you using with this XBMCZ Gotham 13.0?
Thanks.
Originally posted by netguto View PostHi! I use the ROM CS968 - GEASS, comes with libmedia installed. If your rom does not have, you need to replace the file in /system /lib on Android.
Libmedia attached
Thanks, working nicely with TronSmart 908II (http://androidpc.es/blog/2013/08/24/...-externa-wifi/). 1080p streaming great!
A few dependency nags (e.g., Vevo), but that's the case with Gotham in general.
Good work
Hello netguto. Would you be able to elaborate on your settings. What do you have your sound settings set to in the GEASS ROM, and what do you have your audio settings set to in XBMCZ Gotham 13.0 (Libmedia).
Thanks for the help!
Originally posted by el_easy View PostNote: I found your answer in xbmchub forum: For those that are incompatible the easy fix is to change the python version in each respective Addon.xml to 2.1.0.
Look for this line:
And change it to:
Hope this helps.
I am a little bit new on replacing files and modify system files in Android. I have installed your XBMCZ on Kitkat Tech1 modded ROM. Can I still replace the libmedia file as you explained in post#1? Or does it have to be 4.4.2 version?
Pejochto via TapatalkCR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
Originally posted by pejochto View PostI am a little bit new on replacing files and modify system files in Android. I have installed your XBMCZ on Kitkat Tech1 modded ROM. Can I still replace the libmedia file as you explained in post#1? Or does it have to be 4.4.2 version?
The LibMedia.so hack for 4.2 ROM builds will not work with 4.4 ROM builds .... If you want AC3 DTS digital sounds, then please use the built IN "eHomeMediaCenter" or the MXPlayer with custom codecs ... Please go to my threads and read the section "AC3 DTS READY" ...
There are currently 3016 users online. 1 members and 3015 guests.
