TWRP Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
Originally posted by BlackKnight330 View PostFreaktab Rom Developer
Originally posted by BlackKnight330 View PostMarch 2013, I think it might be the hardware, but if i dont use it for awhile then it works fine, but then soon it doesnt work right again.
ShaunMTFreaktab Rom Developer
Originally posted by BlackKnight330 View PostO sry its the next7p12-8gFreaktab Rom Developer
Originally posted by MoeFoh View PostWill TRWP be able to flash the Kyser root package on ANY Nextbook tablet?
If so, it seems to me this would be a stellar way to root your tablet.
Having the recovery boot from the external sd card is an awesome feature.
Is this feature unique to the AMLogic SoC?
MoeFoh
The kyser_root package should work on ANY tablet that uses a UBIFS file system, which includes all of the Amlogic based Nextbooks and is definitely the easiest way to root all of those models. It does require a custom recovery though, as the stock recoveries can only install packages created by Nextbook.
Yes, booting from external SD card is a feature unique to the Amlogic SOC, and it is an awesome feature!
Originally posted by MoeFoh View Post(non-amlogic nextbook tablet)
How would you flash TWRP to the recovery partition if you don't have root yet? Fastboot or ADB, maybe? Seems like a catch 22.
MoeFoh
Originally posted by shaunmt View PostOn a non-amlogic based device, getting recovery installed internally requires either root access, insecure ADB access, or a factory style flash tool that can flash the device in fastboot mode.
ShaunMT
MoeFoh
Originally posted by MoeFoh View PostWould fastboot.exe from a pc cmd prompt work?
MoeFoh
Also, be aware that many stock ROMs include a script in the that runs during boot, which checksums the recovery partition, and if it doesn't match the stock recovery checksum, it reinstalls the stock recovery before booting the Android system.
Originally posted by shaunmt View PostProbably... I'm just starting to work on non Amlogic devices since I picked up the new Nextbook NX785QC8G which is a RockChip RK3188 device. I rooted it with Kingo root. I can either DD the partitions from terminal or ADB or I can use the RKFlash tool with it, but the android SDK fastboot.exe would probably work also.
ShaunMT
MoeFoh
Originally posted by MoeFoh View PostI noticed that TWRP renamed the backup recovery file in the /system dir to *.BAK on my Nextbook tablet.
MoeFoh
Originally posted by MoeFoh View PostWill TRWP be able to make a complete backup of a system that is unrooted?
I ask because it could be useful on a brand new tablet for backing up the virgin stock rom.
MoeFoh
There are currently 2668 users online. 2 members and 2666 guests.
