I have nx007hd8g. I have downloaded and opened the proper zip file for my model. I copied and pasted the uImage_recovery file to the root menu of my ext sd card. I assume upon a reboot while holding the volume key up it should boot the recovery file, however it will only boot into stock recover 3e. Am I missing something simple here? I have tried two separate ext sd cards with the same result. From reading the threads here (many many many times) it should check the ext sd card first before booting stock recovery. Is that correct. Oh, by the way, I am rooted. Did so with cydia impactor and installed SuperSU. Rooting with Cydia was the easiest root I've done for android. Thanks for the wonderful forums. Very informative stuff...
TWRP Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
Only boots into stock 3e recovery
Originally posted by jimlitwiller View PostI have nx007hd8g. I have downloaded and opened the proper zip file for my model. I copied and pasted the uImage_recovery file to the root menu of my ext sd card. I assume upon a reboot while holding the volume key up it should boot the recovery file, however it will only boot into stock recover 3e. Am I missing something simple here? I have tried two separate ext sd cards with the same result. From reading the threads here (many many many times) it should check the ext sd card first before booting stock recovery. Is that correct. Oh, by the way, I am rooted. Did so with cydia impactor and installed SuperSU. Rooting with Cydia was the easiest root I've done for android. Thanks for the wonderful forums. Very informative stuff...
Verify your ro.product.board entry in your build.prop file matches.
Assuming it does, try it again... power down completely, then power on while holding down the volume- key until recovery starts.
If it still doesn't work, try redownloading the file.
If it still doesn't work, post a copy of your stock build.prop file.
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostIt volume- on that model, but yes, it sounds like you've done everything correctly.
ShaunMT
Next8HI8G - TWRP and Kyser Root Zip...
Rooted a friends Next8HI8G using TWRP and Kyser Root Zip file and went without hitch. Fastest root job I have ever done. Clean and quick, no PC required, no fussy ADB driver installation.
Plus, no superuser is installed by Kyser, meaning you can go to the Play Store and download your favorite version. I use the superuser by the guy that developed CWM (what a genius).
I once rooted an old tablet using a PC root program and it installed a CHINESE version of superuser.apk and left no way to uninstall from Settings/Apps. I had to manually remove the superuser app and install a good one.
ShaunMT's porting of TWRP is awesome!!! It really makes the Nextbook tablets more useful and more powerful. Thanks ShaunMT.
MoeFohLast edited by MoeFoh; 13 May 2014, 21:41.
Originally posted by jimlitwiller View PostWell... Got it to work on my Samsung SD card, but not on the PNY SD card. Wonder why? For some reason it just doesn't want to pick up the file. No others similar files on the card. Tried deleting it then pasting it back on several different times, still no luck. If I didn't have so much other junk on there I would try reformatting it. The main thing is, it works! Thanks for the help.
I've bad luck with cheaper SD cards... I know PNY isn't the worst... but I only buy Kingston, Sandisk, Sony or Samsung anymore... what you experienced is often a sign that the card is beginning to fail in my experience...
ShaunMT
MoeFoh
Originally posted by MoeFoh View PostAgree on avoiding the cheap sd cards. Funny thing, I just bought 4 Samsung 16GB cards from Newegg 10 minutes ago at $6 each.
MoeFoh
That's not a bad deal... but I only buy class 10 cards...
I usually get mine from Amazon.
Originally posted by GJPete5580 View PostHello!
The recovery partition on my Next7P12-8G seems to be corrupted
Is there a way to repair. TWRP reports that the internal sdcard has no
room left on it. I can't perform a backup.
What are you trying to backup? Everything? There probably isn't room on the internal SD card... have you tried changing the backup location to the external SD card?
Originally posted by shaunmt View PostI assume you mean there seems to be a problem with the internal recovery partition?
ShaunMT
As I mentioned in an earlier post that I have problems with the
TWRP Recovery on my Next7P12-8G Tablet. And I cannot boot into
the internal recovery. I think it may be corrupted or worse.
Cannot boot into the CWM recovery either.
TWRP reports that 'free space 0 MB' on the internal storage.
I also get the following errors:
E: unable to mount '/emmc'
E: updating partition details...
E: unable to mount internal storage
E: unable to mount /emmc during GUI startup
I try to backup to the external sdcard which TWRP
reports 2489 MB Free Space.
But, when I try to swipe to backup it will not
respond. It will not swipe it just wont respond
to my touch and swiping to the right.
When I boot into the system the internal storage
reports that there is 6.29 GB of free space.
And I can download and store files, video, etc.
However, if I try to boot into recovery the
data on the interal sdcard is erased!
Any Ideas what might be going on!
Thanks!
Thanks!
I think you may have two different problems... unfortunately I don't own this model to do any testing on...
I really can't even attempt to determine what may be wrong with your internal recovery partition. I think the best way to address that issue would be to reflash the ROM...
It does sound like you might have a problem with your internal and / or external SD card...
You should be able to erase / reformat the internal SD card from the android system settings. That may help, especially considering the external SD card is mounted as a folder in the internal SD card...
You might also want to reformat your external SD card to FAT32 using a PC.
In regards to not being able to swipe the slider in TWRP... it is difficult to do on some of the models that I own... this is one of the reasons I did not previously release TWRP... I suspect this is why you can't swipe yours...
On some of the models I own, the slider and buttons in TWRP work perfectly...
On other models, I've found that the touch reactive point seems to be slightly above or below center of the graphic... once you figure out where it is, it easy to get used to.
For the slider, try placing your finger in the center of the circle, or halfway between the center and top, or halfway between the center and bottom of the circle... don't swipe, just touch it and hold your finger there and wait to see if it reacts... if it does, carefully slide straight to the right from that point...
That should enable you to flash, wipe, etc...
Originally posted by BlackKnight330 View PostI think it might be the hardware, but if i dont use it for awhile then it works fine, but then soon it doesnt work right again.I saved the battery and scrapped the rest.
Taking apart the 8P12 was fairly easy. There is a small phillips head screw under the SD card flap and once you remove that you can start prying up on the soft rubber back. One tip: put a little tape to hold the power and volume buttons in place in the case when you remove the guts.
sssteeve
Originally posted by shaunmt View Post/emmc may not mount in TWRP, but that is ok.
ShaunMT
Hello! ShaunMT
I thought I would let you know that I took a chance and used the TWRP Recovery file: SMT_TWRP_Next7P12-4G-POM727MC_1G.zip
for my Next7P12-8G Tablet and it worked! I was able to backup my tablet and then flash your modified stock ROM.
However, WIFI would not work after the flash, so I restored the backup and WIFI is working.
I came across a post in this forum by member Madscientist687 who created a modified stock ROM based on
the Next7P12-8G Tablet with serial #YFG0713..... which is the one I have. So, I flashed it and every thing is
working including the WIFI!
So far I have not experienced any problems by using SMT_TWRP_Next7P12-4G-POM727MC_1G TWRP Recovery.
But, I cant wipe internal storage it fails also, cant do factory reset it also fails.
Thanks Again! For all of your great work with these Nextbook Amlogic Tablets.
If you used the 4G recovery to flash your tablet, be sure to check your partition sizes, as it may have shrunken them... the partition map is har d coded in the boot and recovery kernels.
Also be aware, that serial numbers do not identify tablet models or versions... "YFG0713" means manufactured by Yifang (YFG) in July of 2013 (0713). It could be anything they made that month. Multiple models names or multiple versions of same model name could also be "YFG0713". It's best to compare build.prop file entries to verify if two devices or ROMs are compatible, although even the build.prop may not always be sufficient, as is the case with the WiFi chips in these models, because they didn't change the board name and we don't know the exact date they changed the WiFi chip.
If you have an "original" stock build.prop I'd like to see it.
Originally posted by shaunmt View PostI'm aware that there are two different versions of the Next7P12-8G, with different WiFi chips, but they should both be able to use the same recovery... I know the recoveries are compatible, or people couldn't flashed the ROM with the wrong WiFi chip, as so many did.
ShaunMT
Here is the original build.prop from my Next7P12-8G Tablet that I did a rom dump
when I bought it back in Sept. 2013, that you asked for.
I hope it can be useful to you!
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IMM76I
ro.ota.version.id=V2.0.5.IMM76I.eng.root.20130618
ro.build.display.id=IMM76I.v005
ro.build.version.incremental=eng.root.20130618.142 933
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.4
ro.build.date=Tue Jun 18 14:31:16 CST 2013
ro.build.date.utc=1371537076
ro.build.type=user
ro.build.user=root
ro.build.host=lscao
ro.build.tags=release-keys
ro.product.board=NXM727MC_WM
ro.product.cpu.abi=armeabi-v7a
ro.vendor.name=YFMID
ro.product.model=Next7P12-8G
ro.product.brand=Nextbook
ro.product.name=M727MC
ro.product.device=M727MC
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=YIFANG
ro.wifi.channels=14
ro.board.platform=meson3
# ro.build.product is obsolete; use ro.product.device
ro.build.product=NXM727MC_WM
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=NXM727MC_WM-user 4.0.4 IMM76I eng.root.20130618.142933 release-keys
ro.build.fingerprint=Nextbook/M727MC/M727MC:4.0.4/IMM76I/v005:user/release-keys
ro.build.characteristics=tablet
# end build properties
# system.prop for M1 reference board
# This overrides settings in the products/generic/system.prop file
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=120
keyguard.no_require_sim=1
#set keyguard.enable=false to disable keyguard
keyguard.enable=true
ro.statusbar.widget=true
ro.statusbar.button=true
ro.statusbar.yearmonthdayweek=true
#wifi.interface=ra0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
#wifi.supplicant_scan_interval = 60
#alsa.mixer.playback.master=DAC2 Analog
#alsa.mixer.capture.master=Analog
#configure the Dalvik heap for a standard tablet device.
#frameworks/base/build/tablet-dalvik-heap.mk
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=40m
dalvik.vm.heapsize=256m
hwui.render_dirty_regions=false
# Disable un-supported Android feature
hw.nopm=false
hw.nobattery=false
hw.nophone=false
hw.istablet=true
hw.novibrate=true
hw.has.accessibility.accel=false
hw.cameras=1
hw.hasethernet=false
hw.hasdata=true
ro.platform.has.touch=true
hw.nodatausage=true
# Wi-Fi sleep policy
ro.platform.has.sleeppolicy=false
#set to 0 temporarily so touch works without other changes
ro.sf.hwrotation=270
#0~7 You are required to get the correct install direction according the sensor placement on target board
ro.sf.gsensorposition=4
ro.sf.ecompassposition=4
allow_all_orientations=1
# Use OSD2 mouse patch
ro.ui.cursor=osd2
# Enable 32-bit OSD
sys.fb.bits=32
# Disable GPS
gps.enable=false
# Enable player buildin
media.amsuperplayer.enable=true
media.amplayer.enable-acodecs=asf,wav,aac,m4a,ape,flac,alac
media.amplayer.enable=true
media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
media.amsuperplayer.defplayer=PV_PLAYER
media.amplayer.thumbnail=true
# Status bar customization
ro.statusbar.widget.power=true
# HDMI
ro.hdmi480p.enable=true
rw.fb.need2xscale=ok
media.amplayer.osd2xenable=true
#camera DCIM dir. 0:sd only; 1:nand only; 2,sd first
ro.camera.dcim=1
# Disable preload-class
ro.amlogic.no.preloadclass=0
# App optimization
ro.app.optimization=true
#Dual display
ro.vout.dualdisplay2=true
#For 800x480 UI
ro.platform.UI.800x480=true
#For Erase internal SD card
hw.erase.internalSdcard=true
#audio effect
ro.audioEffectEnabled=true
#Encrypt tablet
#ro.platform.has.security=false
#YF prop
ro.yifang.devicename=Next7P12-8G
ro.yifang.lcd=1
ro.yifang.hotpoint=1
ro.yifang.hdmi=false
ro.yifang.weather.city=New York
ro.yifang.weather.isf=1
ro.yifang.ota.enable=1
ro.fontScale=1.15
virtualsd.enable=true
ro.keyguard.orientation=landscape
#hdmi settings
ro.hdmi.has.settings=false
#used forward seek for libplayer
media.libplayer.seek.fwdsearch=1
#enable address bar cover issue fixing
ro.flashplayer.surfacehack=1
#google client prop
ro.com.google.clientidbase=android-anydata
#enable widevine
media.amplayer.widevineenable=true
#used to set default surface size, set 1 when hwrotation is 270;
media.amplayer.stopbuflevel=0.002
ro.anydata.checkin=true
# ADDITIONAL_BUILD_PROPERTIES
ro.opengles.version=131072
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
drm.service.enabled=true
ro.setupwizard.mode=DISABLED
ro.com.google.gmsversion=4.0_r4
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.hardware.version=1.0.0.0
There are currently 2105 users online. 0 members and 2105 guests.
