TWRP Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
Originally posted by roadkill View PostFreaktab Rom Developer
Hi there. I can't install the twrp on my next book nxt008 HI8G and the board is ebm9009np_w. I downloaded the twrp of the same model and with the board nxt9009np assuming it to be the same as mine. I followed all the instructions and I even tried it on two SD card but still the stock recovery shows up instead of twrp. Am I using the wrong twrp model? Kinda frustrating knowing that everyone who installs it seems to do it successfullyPlease help. Thanks in advance.
PS. It was manufactured in June 2013 by Yifang.
Originally posted by seifcom View PostThank you for eveything mr.shaunmt is there anything new about the next7p12-8g m712mc_mb?Freaktab Rom Developer
Originally posted by supersel07 View PostHi there. I can't install the twrp on my next book nxt008 HI8G and the board is ebm9009np_w. I downloaded the twrp of the same model and with the board nxt9009np assuming it to be the same as mine. I followed all the instructions and I even tried it on two SD card but still the stock recovery shows up instead of twrp. Am I using the wrong twrp model? Kinda frustrating knowing that everyone who installs it seems to do it successfullyPlease help. Thanks in advance.
There is no harm in attempting to boot a recovery from external SD on these tablets, however, if a TWRP for a different model does boot, actually using it to install anything can easily brick a tablet. These amlogic models have their partition layout hard coded in the kernel. If the partition map in the kernel of the recovery doesn't match the partition map in the kernel of your currently installed boot.img, the recovery can overwrite something to the wrong disk location.Freaktab Rom Developer
Originally posted by jacajoy8 View PostSir shaunmt can i try to use your twrp without removing stock recovery? Is there something possible to try first your twrp if will it work or not?
There is no harm in attempting to boot a recovery from external SD on these tablets, HOWEVER, if a TWRP for a different model does boot, actually using it to install anything can easily brick a tablet. These amlogic models have their partition layout hard coded in the kernel. If the partition map in the kernel of the recovery doesn't match the partition map in the kernel of your currently installed boot.img, the recovery can overwrite something to the wrong disk location.Freaktab Rom Developer
Hello, mr. Shaunmt. I have a problem with my nextbook tablet.
The model of my tablet is Nextbook NX008HD8G and the serial number begins with YF1014. Sorry for my english...
What i've done: i only copied SMT_TWRP_Next8HD8G-NXM8000NBD_WMN to my sd card and tried to turn on in recovery mode.
It turn up in TWRP recovery mode normal. The touch and the buttons are working normal.
I just wanted to do a backup with TWRP for the future.
But there's a problem, it doesn't see the internal memory, only the sd card memory.
Then i remove from sdcard uImage_recovery.
now when i try to turn on the tablet it boots only till the second image
I think my mainbord is NBD_WMN version, earlier i install cpu-z
what i did wrong. how can i fix it?
thank you
Originally posted by Eduard Chiperi View PostHello, mr. Shaunmt. I have a problem with my nextbook tablet.
thank you
I would suggest trying to get it to boot TWRP from external SD CARD again, then either restore from backup, or try installing my ROM for your model.Freaktab Rom Developer
but that's the problem. It seems that those TWRP don't work normal with my tablet model
mine is similar with mr. xxSAKISxx from the forum above, his serial number is YF071438021, mine is YF101401991.
I think that are the similar models and his build prop. is like mine. and i read above in the forum that you did not release TWRP and ROMS for these models
Thanks in advance
There are currently 3090 users online. 2 members and 3088 guests.
