TWRP Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=JRO03C
    ro.ota.version.id=V1.0.5.JRO03C.user.root.20131028
    ro.build.display.id=V1.0.5.JRO03C.user.root.201310 28
    ro.build.version.incremental=eng.root.20131028.110 616
    ro.build.version.sdk=16
    ro.build.version.codename=REL
    ro.build.version.release=4.1.1
    ro.build.date=Mon Oct 28 11:06:47 CST 2013
    ro.build.date.utc=1382929607
    ro.build.type=user
    ro.build.user=root
    ro.build.host=midsc-P67-DS3-B3
    ro.build.tags=release-keys
    ro.product.board=EBM8000NBD
    ro.vendor.name=YFMID
    ro.product.model=EBM8000NBD
    ro.product.brand=MID
    ro.product.name=EBM8000NBD
    ro.product.device=EBM8000NBD
    ro.product.cpu.abi2=armeabi
    ro.product.cpu.abi=armeabi-v7a
    ro.product.manufacturer=YIFANG
    ro.wifi.channels=14
    ro.board.platform=meson6
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=EBM8000NBD
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.description=EBM8000NBD-user 4.1.1 JRO03C eng.root.20131028.110616 release-keys
    ro.build.fingerprint=MID/EBM8000NBD/EBM8000NBD:4.1.1/JRO03C/eng.root.20131028.110616:user/release-keys
    ro.build.characteristics=tablet
    # end build properties
    # system.prop for M1 reference board
    # This overrides settings in the products/generic/system.prop file
    #rild.libpath=/system/lib/libreference-ril.so
    #rild.libargs=-d /dev/ttyS0
    ro.sf.lcd_density=160
    keyguard.no_require_sim=1
    #set keyguard.enable=false to disable keyguard
    keyguard.enable=true
    ro.statusbar.widget=true
    ro.statusbar.button=true
    ro.statusbar.yearmonthdayweek=true
    #wifi.interface=ra0
    # Time between scans in seconds. Keep it high to minimize battery drain.
    # This only affects the case in which there are remembered access points,
    # but none are in range.
    #wifi.supplicant_scan_interval = 60
    #alsa.mixer.playback.master=DAC2 Analog
    #alsa.mixer.capture.master=Analog
    #configure the Dalvik heap for a standard tablet device.
    #frameworks/base/build/tablet-dalvik-heap.mk
    dalvik.vm.heapstartsize=5m
    dalvik.vm.heapgrowthlimit=48m
    dalvik.vm.heapsize=256m
    hwui.render_dirty_regions=false
    media.amplayer.v4osd.enable=1
    gadget.nand.force_sync=true
    # Disable un-supported Android feature
    hw.nopm=false
    hw.nobattery=false
    hw.nophone=false
    hw.novibrate=true
    hw.cameras=2
    hw.hasethernet=false
    #hw.hasdata=true
    ro.platform.has.touch=true
    # Wi-Fi sleep policy
    ro.platform.has.sleeppolicy=false
    #set to 0 temporarily so touch works without other changes
    ro.sf.hwrotation=270
    #0~7 You are required to get the correct install direction according the sensor placement on target board
    #ro.sf.gsensorposition=6
    #ro.sf.Gconvert_x_y=0
    #ro.sf.Gconvert_x=1
    #ro.sf.Gconvert_y=1
    #ro.sf.Gconvert_z=1
    ro.sf.ecompassposition=4
    allow_all_orientations=1
    # Set Camera Orientation
    # Use OSD2 mouse patch
    ro.ui.cursor=osd2
    ro.hardware=amlogic
    # Enable 32-bit OSD
    sys.fb.bits=32
    # Disable GPS
    gps.enable=false
    # Enable player buildin
    media.amsuperplayer.enable=true
    media.amplayer.enable-acodecs=asf,aac,ape,flac,alac
    media.amplayer.enable=true
    media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
    media.amsuperplayer.defplayer=PV_PLAYER
    media.amplayer.thumbnail=true
    #media.amplayer.widevineenable=true
    media.arm.audio.decoder=ape,aac
    #reduce the time of loading online video
    media.libplayer.fastswitch=1
    media.amplayer.delaybuffering=1
    media.libplayer.ipv4only=1
    media.amplayer.stopbuflevel=0.002
    #for online video show loading icon too frequently
    media.amplayer.buffertime=15
    #fix online video block issue
    libplayer.livets.softdemux=1
    libplayer.netts.recalcpts=1
    #v4osd for chrome video
    media.amplayer.dsource4local=1
    # Nand write need force sync when gadget
    # Status bar customization
    ro.statusbar.widget.power=true
    yf.show.compat=false
    # HDMI
    ro.hdmi480p.enable=false
    #rw.fb.need2xscale=ok
    #media.amplayer.osd2xenable=true
    #camera DCIM dir. 0:sd only; 1:nand only; 2,sd first
    ro.camera.dcim=1
    ro.camera.lockorientation=false
    # Disable preload-class
    ro.amlogic.no.preloadclass=0
    # App optimization
    ro.app.optimization=true
    #Dual display
    ro.vout.dualdisplay3=true
    ro.vout.player.exit=false
    # CPU settings
    ro.has.cpu.setting=true
    # CPU freq customized in setting menu
    # normal, performance, powersaving
    ro.cpumode.maxfreq=1200000,1320000,800000
    # when usbstorage, CPU mode and freq
    ro.usbstorage.cpumode=performance
    ro.usbstorage.maxfreq=600000
    ro.bootanimation.rotation=90
    #used to set default surface size, set 1 when hwrotation is 270, set 3 when hwrotation is 90;need set ro.bootanimation.rotation 0;
    #debug.default.dimention=1
    #YF prop
    ro.yifang.devicename=NX008HD8G
    ro.yifang.hotpoint=0
    ro.keyguard.orientation=landscape
    ro.yifang.weather.city=New@York
    ro.yifang.weather.isf=1
    ro.yifang.ota.enable=0
    #hdmi settings
    ro.hdmi.has.settings=false
    #support internal storage erase
    has.media.poll=false
    ro.dongle.change.local=0
    ro.yifang.locationsetting=1
    #used forward seek for libplayer
    media.libplayer.seek.fwdsearch=1
    #enable address bar cover issue fixing
    ro.flashplayer.surfacehack=1
    ro.media.partition.label=NX008HD8G
    hw.erase.internalSdcard=true
    ro.screen.has.usbstorage=true
    virtualsd.enable=true
    ro.yifang.bluetooth=0
    ro.yifang.mobile=1
    ro.yifang.mobile_dongle=0
    ro.yifang.default.timeout=60000
    ro.yifang.default.brightness=128
    #google client prop
    ro.com.google.clientidbase=android-anydata
    ro.com.google.gmsversion=4.1_r4
    ro.yifang.datausagesetting=1
    ro.product.mobilenetwork = 0
    #enable widevine
    #ro.setupwizard.mode=OPTIONAL
    ro.anydata.checkin=true
    ro.audioEffectEnabled=true
    ro.app.hdmi.allswitch=true
    ro.rk.bt_enable=0
    # ADDITIONAL_BUILD_PROPERTIES
    ro.com.android.dateformat=MM-dd-yyyy
    ro.config.ringtone=Ring_Synth_04.ogg
    drm.service.enabled=true
    ro.carrier=wifi-only
    ro.opengles.version=131072
    ro.config.notification_sound=OnTheHunt.ogg
    ro.config.alarm_alert=Alarm_Classic.ogg
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    ro.hardware.version=1.0.0.0
    here is the mrs. xxSAKISxx build.prop and i believe that mine is the same
    and you wrote above that you did not see this board before and that you received a dump from one of these...
      and i think if i'll flash with one of your roms, i'll brick the tablet at all...
      am i right?
        hi, mr. shaunmt
        just giving you a reminder that I still looking forward for your help...
        please...
          So I'm new to this could you give me a lil more detail to what exactly I be doing
            I'm new to this could you give me more detail on the process
              it seems that this forum is dead, unfortunately....
                With Twrp recovery its so easy to backup&root it seemed hard at first but its very easy i downloaded a unzip app i unzipped twrp i put the ulmage recovery on my external sd powered off nx008hd8g opened up twrp with power&+volume button perform a backup reboot dowloaded kyser root open up twrp go to install find kyser root & tap install reboot to root easy peesy
                  I found my nx008hd8g ro.product.board with Prop build editor app
                    what's your serial number?
                    and your ro.product.board name?
                      Could you please make a custom recovery for my nextbook 7/NX700qc I changed my build prop and I am stuck HELP!!
                        Originally posted by seifcom View Post
                        Thank you for eveything mr.shaunmt is there anything new about the next7p12-8g m712mc_mb?
                        Hi
                        I have just registered to put a feedback....
                        I had the same model "next7p12-8g", with motherboard number "m712mc_mb" , the tablet was stuck in the first screen (Abraham Lincoln's saying about the books).
                        Few times of Factory reset did not helped, so TWRP was the only hope.
                        Finally I have completed the firmware update using SMT_TWRP_Next7P12-8G-NXM727MC_WM.zip as the program and SMT-Next7P12-8G-NXM727MC_WM-082313-8188eu_wifi.zip as a firmware.
                        My WiFi card was RTL8188 so this firmware was the correct one for the WiFi.
                        I can confirm that there was a major problem with TWRP having problems with the touch screen, even clicking on a simple buttons was like 1/4 of a success.
                        The slider for confirming the flash was a finale, but after a few days of trying , I got lucky. The slider moved to the right end, when most of the time it was not moving at all.
                        Even going to the halfway was a rare success. I understood that I should make the whole movement to the right, even the slider didn't wanted to move at all. As said, finally i have succeeded.
                        So, it was not about the center of the touch being displaced (maybe it was displaced a bit to the up side, but that was not the major problem).
                        It was more about the pressure of the finger (This was mentioned in one of the previous pages). I have succeeded with more like lighter pressure on the touch screen.
                        Otherwise, programming the firmware went without problems, first starting of the tablet was slower, which is understandable, WiFi worked as well.
                        BIG Thanks to Freaktab and Shaunmt for making this possible.
                          Hi there, the download link for the TWRP recovery for NX007HD8G doesn't seem to be working for me. Has the link been closed?
                            The link seems to be broken, I have an old copy (SMT_TWRP_Next8HD8G-NXM8000ND_WM.zip), if you'd like I could upload it for you.
                            Nextbook NX008HD8G - Rooted
                              I don't suppose that that one would work for the NX007HD8G? shaunmt's link is to a file called SMT_TWRP_Next7HD8G-NXM7000NBD_WMN.zip
                              But if it is suitable I'd be grateful!
                                My bad, I didn't pay enough attention & got the models mixed up. Unfortunately it won't work as far as I know.
