GT-N7000...
Beelink M8 / S82 vs M8 Box (square)
Originally posted by Javimetal View PostBy the way, I see MX is using a steel plate in their products over the heatsink. As we have been designing a fanless heat sink, I can not understand why they use this material there. Same than the square M8.
Aluminium 205 W/m°C (light and cheap)
Copper 400W/m°C (but expensive and difficult to make)
Steel 45 W/m°C (heavy metal)
Why to use steel?
Guest
Some boxes, speakers hdd etc., emit strong electromagnetic fields, so the steel provides a small measure of protection. Could be weight factor too.
Also on M8, I put a thin bit of tape on the front lighted triangular plastic to hide the blue light and remote stopped working. Every little makes a difference sometimes. Anyone wanting better remote pickup: remove the triangular white plastic.
Ynt: Beelink M8 / S82 vs M8 Box (square)
Why to use steel?
Here is the topic: http://www.FreakTab.com/showthread.php?t=16055
GT-N7000...
Originally posted by inflock View PostWhat do you think about this CSM8 board looks very masculer.
GT-N7000...
If the factories begin to put more attention and don't try to save $0.01 from here and there it's a big step for all of us.Android TV Box direct from China. English & Español
There are currently 2573 users online. 0 members and 2573 guests.
