The USB drive is fine if i attach it via a powered hub, but if I plug it in to the back of the CX919ii then I get this problem. Flashing a 720 kernel seems to solve the problem and my flash drive works happily. My flash drive also worked well when i was on stock.
Ideally I'd not like to have to carry around a USB hub, and would like to leave the flash drive plugged in permanently on a 1080p setup. I'm a a newbie to all this so can anyone tell me what might be going wrong, recommend a solution, or possibly recommend a different HD kernel to try?
Thanks in advance.
