XBMC Gotham 13 stable Allwinner A31 problem
Why not make 1 post.. with your questions?
Is there linux for your box..
Yes
--note that android is based on linux
Xbmc v13.. doesnt work on my unit cs918s fw v1rc3
--blackscreen with sound
Your box comes with VidonMe Tv (a special build of xbmc that uses a external player)
What firmware version are you running?
Do you have the mele with external antenna or without?
Some gamepads do work.. what kind do you have?
Bluetooth dongels rarly work..
-i prefer using logitech unifying dongle ( combine key&mouse
Update
I watched your review..
--looking goodLast edited by mitchell4you; 08 May 2014, 16:48.
Yes
my box is the one with the external antenna and it has the vidon.me xbmc version but mine is not using an external player. It plays 1080p perfect though but i have a buffering problem. After 20 minutes or so the movie keeps buffering after 1 second of playback. I tweaked the advancedsettings.xml but gave me the same results, that's why i want the stable gotham 13, but it doesn't work. I get the same as you, only sound.
My firmware version is the latest v3.1.3
The gamepad i have is a playstation 2 gamepad and i am using these usb adapters
On my RK3188 TV Box i just connect them and it recognizes them automatically.
With my Mele A1000G there is no detection
P.S: I haven't found a linux image for Allwinner A31 in the link you provided
I have an allwinner a31 here that I have been using to test gotham and it has been working fine.
I uninstalled vidon.me then installed gotham and went to gotham settings and the video section. You then change the settings to expert mode down the bottom and once that is done you can enter the acceleration menu and turn off mediacodec, leave libstagefright enabled.
Once i had done that my movies played back fine even my 1080p stuff.To Infinity and Beyond.... XBMC
Originally posted by Flumpster View PostI have an allwinner a31 here that I have been using to test gotham and it has been working fine.
Originally posted by convict View PostDo I have to uninstall vidon.me? I tried what you said but it still doesn't workTo Infinity and Beyond.... XBMC
Originally posted by convict View PostWhat device do you have?
Model Number : CS918s
Android Version : 4.2.2
Firmware Version : v1.0rc3
Kernel Version : 3.3.0 ch@ck-desktop #47
Build Number : mars_ov5640-eng 4.2.2. JDQ39
If I google the CS918s it shows me this :
Mine looks the same but without the camera.
When I boot it up I get 4 sqaures animated that says MBOX or something.To Infinity and Beyond.... XBMC
Originally posted by Flumpster View PostThis is what I am not 100 percent sure of. It looks identical to my K-r42s and T-R42s and was actually sent to me as a replacement for a faulty K-R42.
Originally posted by convict View PostYours has the a31s mine has the a31, they are completely different socs
Wierd..
I re-installed xbmc.. (before.. i did a upgrade from rc1)(re-install after android/data/xbmc deletion)
Hw is working now!
But,
Still same issues
-xbmc says No internet connection (ip / dns ect are looking good) ( using wifi)
-addons do work.. if installed manual ( with-out repro) (watching filmOn tv)
-common cache fail error
-lots of addon errors
Only xbmc version that works great is SPMC 1.4 with stagefright enabled ( non lib-media edition )
Cheers
Hw is working now!
But,
Still same issues
Cheers
See: post your build.prop section
Some allwinner units have Stagefrightlib/entry's
Note..
After install and enabling stagefright and disable mediacodec.. after playing first vid..
It sometimes crashes to desktop.. just hit 'power-off' button on remote
On the next power-up stagefright should work.. (it requires/ask's for root access )
-xbmc v13 only seems to run proper if you have root access
But..
Any solution.. for the 'Not connected' issue.. ?
I will.. give v13.1 beta a try.. if that fails perhaps the v14a
Note..
But..
There are currently 2971 users online. 2 members and 2969 guests.
