I didn't try i yet because i am not formiliar with installing new firmware.
new firmware cx-919 ii
New Firmware Allminipc KitKat 4.4.2 for CX-919 II
http://allminipc.com/forum/viewtopic.php?f=3&t=1185Last edited by dimon4ik86; 12 May 2014, 16:15.
Re: new firmware cx-919 ii
Originally posted by dimon4ik86 View Postin settings I can not turn on location. with you too or does it?
Verstuurd vanaf mijn ZP980 met Tapatalk
Originally posted by albinonotjes View PostTo bad that NPO does not work. Do you have a solution to get NPO running. that was one of the reasons that I bought the CX-919 II.
Originally posted by jg77 View PostI haven't seen the NPO app running on any Android stick or box with either 4.2 and 4.4. That is still a big issue for NPO which they should fix. I use the XBMC addons to view their streams. I have the cx-919ii and the Minix Neo X7 both same results.
But the latest official (non-beta) ROMS cause trouble with the NPO and RTL XL app for me too. For example the NPO app won't start any streams and the RTL XL app won't load video's.
So for now I stick to the beta rom where the NPO and RTL XL do work.
I wish I could use these new kernels 4.x from d33, but they are not supported/working with the beta ROMS.
XBMC indeed works fine on any ROM.
Device: CX919-II
Kernel 2.07 d33
Finless ROM 2.0 4.4.2 kitkat BETA.
Originally posted by roooii View PostI do run NPO app without problems on 4.4.2 kitkat beta.
Device: CX919-II
Kernel 2.07 d33
The overall performance of the official 4.4 rom is good, startup from cold boot is fast, switching between apps is very good. Also I now finally can use the build-in bluetooth for my keyboard from like 4 meters away.
Can you tell me a bit about the rom you are using, your experience?
Originally posted by jg77 View PostIt is strange though, the NPO 'uitzending gemist' part of the app is starting the stream and then after like 15 minutes or so it never stops buffering, the stream quality is pretty good though.
There are currently 2225 users online. 1 members and 2224 guests.
