The problem I have is the "T" in the 3188T , they throttled back the performance so xbmc videos aren't smooth, that's why in looking for a Linux build to try
FVIEW U2 TV BOX Mini PC RK3188T Quad Core root? Help
I ended up selling mine before even upacking.
I'll get another one in a few weeks and will report back.
Btw, do i need to root it in to get better performance, i.e higher CPU frequency as pointed out by someone here?
Originally posted by Blindseyed View PostNo problem I usually got to the official XBMC page for stable versions.
let me know how it performs
Originally posted by fossxplorer View PostI ended up selling mine before even upacking.
I am still looking for a way to put Linux or openElec on the Fview to see if that will make the video better but It seems there's no builds for RK3188 anywhere
I purchased this unit mainly because it was so cheap. Rooting the device is just a matter of placing Finless’ Neo X7 update.zip on an sd card and installing the update. Installing CWM from http://androtab.info/clockworkmod/rockchip/ doesn't work - it checks whether the device identifier is rk30sdk or rk3066, whereas this unit identifies itself as rk31sdk. It shouldn't be too hard to fix that.
It's a potentially very powerful unit, especially for the price. 4x 1.4GHz Cortex A9, Mali-400, 2GB RAM. All it takes is better software to unleash the potential.
Yes, i agree with you. As @Nut and Bolt points out i also buy these since it's kinda cheap.
And i'd also think that it might be useful for my kids, but is there an issue with video playback?
What's good with openElec vs XBMC on Android? I though Android is very convenient for all the apps, games + XBMC etc?
I know S802 has MALI 450 which is better than MALI-400 which is in RK3188.
Linux on this device would be nice for my other purposes to have a small 24/7 device to run ssh/cups etc.
Originally posted by Blindseyed View PostYes rooting it makes it faster with overclocking but in all honesty, if I were you I'd get the M8 s802 or something similar, it's alittle more but worth it, I only use the Fview box in my bedroom mainly for my littlest kid to watch movies /cartoons while getting ready . I have the M8 in my lvg rm running openElec and it's pretty much flawless.
Originally posted by fossxplorer View PostLinux on this device would be nice for my other purposes to have a small 24/7 device to run ssh/cups etc.
I've used Debian Kit and it's running openssh-server nicely already
Originally posted by fossxplorer View PostBlindseyed, thx for your reply here + priv msg
It sounds really good. One more question though: does it support DTS? Anyone actually tested it?
yes it has DTS, I hooked it straight into my reciever and got 5.1 with everything including XBMC
I need some help with the rom.
I accidently crash the tv box by trying to unroot it.
So I flash it with the Kitkat 4.4 rom from other manufactures.
the rom works fine with image and sound, but not with wifi, bluetooth, lan and IR remote.
I wonder if anyone could kind enough to dump the original rom and share it please.
Thx
There are currently 1509 users online. 1 members and 1508 guests.
