Do i have to edit build.prop? Or do i have to download a 720 fw? I noticed the finless rom for another device had different kernels for 1080 and 720.
720 kernel / fw for m8
Since i can't change the windowed 1920-1080 to 1280-720 within xbmc, I'm looking for a 1280:720 firmware / kernel for the m8 since my tv is 720. With the 1080 fw the original picture is not centered in my screen.
Do i have to edit build.prop? Or do i have to download a 720 fw? I noticed the finless rom for another device had different kernels for 1080 and 720. -
Originally posted by Marton4 View PostSince i can't change the windowed 1920-1080 to 1280-720 within xbmc, I'm looking for a 1280:720 firmware / kernel for the m8 since my tv is 720. With the 1080 fw the original picture is not centered in my screen.
I have never tried an amlogic M8, but in amlogic-mx devices resolution can be controlled via fbset binary.In amlogic MX there is a file called set_display_mode.sh in system/bin which is run every boot to determine device resolution. Not sure if Amlogic M8 are the same, but amlogic is very "traditional" and probably they use the same to call a different resolution. I would check it out.
Originally posted by skelton View PostI have never tried an amlogic M8, but in amlogic-mx devices resolution can be controlled via fbset binary.In amlogic MX there is a file called set_display_mode.sh in system/bin which is run every boot to determine device resolution. Not sure if Amlogic M8 are the same, but amlogic is very "traditional" and probably they use the same to call a different resolution. I would check it out.
The script is there. Here is the code:
Code:#!/system/bin/sh case `getprop sys.fb.bits` in 32) osd_bits=32 ;; *) osd_bits=16 ;; esac #if [ -e /dev/dvb0.frontend0 ]; then # DVB_EXIST=yes #else DVB_EXIST=no #fi hpdstate=$(cat /sys/class/amhdmitx/amhdmitx0/hpd_state) if [ "$(getprop ro.platform.hdmionly)" = "true" ]; then if [ "$hpdstate" = "1" ]; then outputmode=$(getprop ubootenv.var.hdmimode) setprop ubootenv.var.outputmode $outputmode else outputmode=$(getprop ubootenv.var.cvbsmode) setprop ubootenv.var.outputmode $outputmode fi else outputmode=$(getprop ubootenv.var.outputmode) fi scalemode=$(getprop ro.platform.has.1080scale) if [ "$(getprop ro.platform.has.cvbsmode)" = "true" ]; then cvbsmode=$(getprop ubootenv.var.cvbsmode) if [ "$outputmode" = "480i" -o "$outputmode" = "576i" ]; then echo null > /sys/class/display2/mode #if [ "$cvbsmode" = "480cvbs" ]; then elif [ "$cvbsmode" = "480cvbs" ]; then echo null > /sys/class/display2/mode echo 480cvbs > /sys/class/display2/mode echo 1 > /sys/class/video2/screen_mode elif [ "$cvbsmode" = "576cvbs" ]; then echo null > /sys/class/display2/mode echo 576cvbs > /sys/class/display2/mode echo 1 > /sys/class/video2/screen_mode else echo null > /sys/class/display2/mode echo 480cvbs > /sys/class/display2/mode echo 1 > /sys/class/video2/screen_mode setprop ubootenv.var.cvbsmode 480cvbs fi if [ "$outputmode" = "1080p" -o "$outputmode" = "1080i" -o "$outputmode" = "1080p50hz" -o "$outputmode" = "1080i50hz" -o "$outputmode" = "4k2k24hz" -o "$outputmode" = "4k2k25hz" -o "$outputmode" = "4k2k30hz" -o "$outputmode" = "4k2ksmpte"] ; then echo 960 > /sys/module/amvideo2/parameters/clone_frame_scale_width else echo 0 > /sys/module/amvideo2/parameters/clone_frame_scale_width fi fi #if [ "$scalemode" = "2" ] ; then #if [ $DVB_EXIST = yes ]; then #echo 0 0 1280 720 0 0 1240 690 > /sys/class/display/axis #else #echo 0 0 1280 720 0 0 18 18 > /sys/class/display/axis #fi if [ "$outputmode" = "1080p" -o "$outputmode" = "1080i" -o "$outputmode" = "1080p50hz" -o "$outputmode" = "1080i50hz" -o "$outputmode" = "4k2k24hz" ] ; then setprop ro.sf.lcd_density 240 else setprop ro.sf.lcd_density 160 fi sleep 1 #fi print outputmode = $outputmode case $outputmode in 4k2k24hz) scaleenable=true scaledir=up if [ "$(getprop ubootenv.var.4k2k24hz_x)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.4k2k24hz_x) fi if [ "$(getprop ubootenv.var.4k2k24hz_y)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.4k2k24hz_y) fi if [ "$(getprop ubootenv.var.4k2k24hz_width)" = "" ] ; then outputwidth=3840 else outputwidth=$(getprop ubootenv.var.4k2k24hz_width) fi if [ "$(getprop ubootenv.var.4k2k24hz_height)" = "" ] ; then outputheight=2160 else outputheight=$(getprop ubootenv.var.4k2k24hz_height) fi ;; 4k2k25hz) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.4k2k25hz_x)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.4k2k25hz_x) fi if [ "$(getprop ubootenv.var.4k2k25hz_y)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.4k2k25hz_y) fi if [ "$(getprop ubootenv.var.4k2k25hz_width)" = "" ] ; then outputwidth=3840 else outputwidth=$(getprop ubootenv.var.4k2k25hz_width) fi if [ "$(getprop ubootenv.var.4k2k25hz_height)" = "" ] ; then outputheight=2160 else outputheight=$(getprop ubootenv.var.4k2k25hz_height) fi ;; 4k2k30hz) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.4k2k30hz_x)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.4k2k30hz_x) fi if [ "$(getprop ubootenv.var.4k2k30hz_y)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.4k2k30hz_y) fi if [ "$(getprop ubootenv.var.4k2k30hz_width)" = "" ] ; then outputwidth=3840 else outputwidth=$(getprop ubootenv.var.4k2k30hz_width) fi if [ "$(getprop ubootenv.var.4k2k30hz_height)" = "" ] ; then outputheight=2160 else outputheight=$(getprop ubootenv.var.4k2k30hz_height) fi ;; 4k2ksmpte) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.4k2ksmpte_x)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.4k2ksmpte_x) fi if [ "$(getprop ubootenv.var.4k2ksmpte_y)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.4k2ksmpte_y) fi if [ "$(getprop ubootenv.var.4k2ksmpte_width)" = "" ] ; then outputwidth=4096 else outputwidth=$(getprop ubootenv.var.4k2ksmpte_width) fi if [ "$(getprop ubootenv.var.4k2ksmpte_height)" = "" ] ; then outputheight=2160 else outputheight=$(getprop ubootenv.var.4k2ksmpte_height) fi ;; 480p) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.480poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.480poutputx) fi if [ "$(getprop ubootenv.var.480poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.480poutputy) fi if [ "$(getprop ubootenv.var.480poutputwidth)" = "" ] ; then outputwidth=720 else outputwidth=$(getprop ubootenv.var.480poutputwidth) fi if [ "$(getprop ubootenv.var.480poutputheight)" = "" ] ; then outputheight=480 else outputheight=$(getprop ubootenv.var.480poutputheight) fi ;; 480i) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.480ioutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.480ioutputx) fi if [ "$(getprop ubootenv.var.480ioutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.480ioutputy) fi if [ "$(getprop ubootenv.var.480ioutputwidth)" = "" ] ; then outputwidth=720 else outputwidth=$(getprop ubootenv.var.480ioutputwidth) fi if [ "$(getprop ubootenv.var.480ioutputheight)" = "" ] ; then outputheight=480 else outputheight=$(getprop ubootenv.var.480ioutputheight) fi ;; 480cvbs) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.480ioutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.480ioutputx) fi if [ "$(getprop ubootenv.var.480ioutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.480ioutputy) fi if [ "$(getprop ubootenv.var.480ioutputwidth)" = "" ] ; then outputwidth=720 else outputwidth=$(getprop ubootenv.var.480ioutputwidth) fi if [ "$(getprop ubootenv.var.480ioutputheight)" = "" ] ; then outputheight=480 else outputheight=$(getprop ubootenv.var.480ioutputheight) fi ;; 576p) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.576poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.576poutputx) fi if [ "$(getprop ubootenv.var.576poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.576poutputy) fi if [ "$(getprop ubootenv.var.576poutputwidth)" = "" ] ; then outputwidth=720 else outputwidth=$(getprop ubootenv.var.576poutputwidth) fi if [ "$(getprop ubootenv.var.576poutputheight)" = "" ] ; then outputheight=576 else outputheight=$(getprop ubootenv.var.576poutputheight) fi ;; 576i) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.576ioutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.576ioutputx) fi if [ "$(getprop ubootenv.var.576ioutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.576ioutputy) fi if [ "$(getprop ubootenv.var.576ioutputwidth)" = "" ] ; then outputwidth=720 else outputwidth=$(getprop ubootenv.var.576ioutputwidth) fi if [ "$(getprop ubootenv.var.576ioutputheight)" = "" ] ; then outputheight=576 else outputheight=$(getprop ubootenv.var.576ioutputheight) fi ;; 576cvbs) scaleenable=true scaledir=down if [ "$(getprop ubootenv.var.576ioutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.576ioutputx) fi if [ "$(getprop ubootenv.var.576ioutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.576ioutputy) fi if [ "$(getprop ubootenv.var.576ioutputwidth)" = "" ] ; then outputwidth=720 else outputwidth=$(getprop ubootenv.var.576ioutputwidth) fi if [ "$(getprop ubootenv.var.576ioutputheight)" = "" ] ; then outputheight=576 else outputheight=$(getprop ubootenv.var.576ioutputheight) fi ;; 720p) scaleenable=false scaledir=down if [ "$(getprop ubootenv.var.720poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.720poutputx) fi if [ "$(getprop ubootenv.var.720poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.720poutputy) fi if [ "$(getprop ubootenv.var.720poutputwidth)" = "" ] ; then outputwidth=1280 else outputwidth=$(getprop ubootenv.var.720poutputwidth) fi if [ "$(getprop ubootenv.var.720poutputheight)" = "" ] ; then outputheight=720 else outputheight=$(getprop ubootenv.var.720poutputheight) fi ;; 1080p) scaleenable=false scaledir=up if [ "$(getprop ubootenv.var.1080poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.1080poutputx) fi if [ "$(getprop ubootenv.var.1080poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.1080poutputy) fi if [ "$(getprop ubootenv.var.1080poutputwidth)" = "" ] ; then outputwidth=1920 else outputwidth=$(getprop ubootenv.var.1080poutputwidth) fi if [ "$(getprop ubootenv.var.1080poutputheight)" = "" ] ; then outputheight=1080 else outputheight=$(getprop ubootenv.var.1080poutputheight) fi ;; 1080i) scaleenable=false scaledir=up if [ "$(getprop ubootenv.var.1080ioutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.1080ioutputx) fi if [ "$(getprop ubootenv.var.1080ioutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.1080ioutputy) fi if [ "$(getprop ubootenv.var.1080ioutputwidth)" = "" ] ; then outputwidth=1920 else outputwidth=$(getprop ubootenv.var.1080ioutputwidth) fi if [ "$(getprop ubootenv.var.1080ioutputheight)" = "" ] ; then outputheight=1080 else outputheight=$(getprop ubootenv.var.1080ioutputheight) fi ;; 1080i50hz) scaleenable=false scaledir=up if [ "$(getprop ubootenv.var.1080ioutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.1080ioutputx) fi if [ "$(getprop ubootenv.var.1080ioutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.1080ioutputy) fi if [ "$(getprop ubootenv.var.1080ioutputwidth)" = "" ] ; then outputwidth=1920 else outputwidth=$(getprop ubootenv.var.1080ioutputwidth) fi if [ "$(getprop ubootenv.var.1080ioutputheight)" = "" ] ; then outputheight=1080 else outputheight=$(getprop ubootenv.var.1080ioutputheight) fi ;; 1080p50hz) scaleenable=false scaledir=up if [ "$(getprop ubootenv.var.1080poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.1080poutputx) fi if [ "$(getprop ubootenv.var.1080poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.1080poutputy) fi if [ "$(getprop ubootenv.var.1080poutputwidth)" = "" ] ; then outputwidth=1920 else outputwidth=$(getprop ubootenv.var.1080poutputwidth) fi if [ "$(getprop ubootenv.var.1080poutputheight)" = "" ] ; then outputheight=1080 else outputheight=$(getprop ubootenv.var.1080poutputheight) fi ;; 720p50hz) scaleenable=false scaledir=down if [ "$(getprop ubootenv.var.720poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.720poutputx) fi if [ "$(getprop ubootenv.var.720poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.720poutputy) fi if [ "$(getprop ubootenv.var.720poutputwidth)" = "" ] ; then outputwidth=1280 else outputwidth=$(getprop ubootenv.var.720poutputwidth) fi if [ "$(getprop ubootenv.var.720poutputheight)" = "" ] ; then outputheight=720 else outputheight=$(getprop ubootenv.var.720poutputheight) fi ;; *) outputmode=1080p scaleenable=false scaledir=up if [ "$(getprop ubootenv.var.1080poutputx)" = "" ] ; then outputx=0 else outputx=$(getprop ubootenv.var.1080poutputx) fi if [ "$(getprop ubootenv.var.1080poutputy)" = "" ] ; then outputy=0 else outputy=$(getprop ubootenv.var.1080poutputy) fi if [ "$(getprop ubootenv.var.1080poutputwidth)" = "" ] ; then outputwidth=1920 else outputwidth=$(getprop ubootenv.var.1080poutputwidth) fi if [ "$(getprop ubootenv.var.1080poutputheight)" = "" ] ; then outputheight=1080 else outputheight=$(getprop ubootenv.var.1080poutputheight) fi esac if [ "$outputmode" = "480i" -o "$outputmode" = "576i" ]; then if [ "$(getprop ro.platform.has.cvbsmode)" = "true" ] ; then if [ "$outputmode" = "480i" ];then echo 480cvbs > /sys/class/display/mode echo null > /sys/class/display2/mode else echo 576cvbs > /sys/class/display/mode echo null > /sys/class/display2/mode fi else echo $outputmode > /sys/class/display/mode fi else echo $outputmode > /sys/class/display/mode fi if [ "$(getprop ro.platform.has.realoutputmode)" != "true" ] ; then busybox echo $outputx $outputy $(($outputwidth + $outputx - 1)) $(($outputheight + $outputy - 1)) 0 > /sys/class/ppmgr/ppscaler_rect echo 1 > /sys/class/graphics/fb0/free_scale echo 1 > /sys/class/graphics/fb1/free_scale else if [ "$scaledir" = "down" ]; then echo 0 0 1280 720 $outputx $outputy 18 18 > /sys/class/display/axis else echo 0 0 1920 1080 $outputx $outputy 18 18 > /sys/class/display/axis fi echo 1 > /sys/class/graphics/fb0/freescale_mode echo 1 > /sys/class/graphics/fb1/freescale_mode echo 0 0 1919 1079 > /sys/class/graphics/fb0/free_scale_axis echo $outputx $outputy $(($outputwidth + $outputx - 1)) $(($outputheight + $outputy - 1)) > /sys/class/video/axis echo $outputx $outputy $(($outputwidth + $outputx - 1)) $(($outputheight + $outputy - 1)) > /sys/class/graphics/fb0/window_axis echo 0 > /sys/class/graphics/fb0/blank fi if [ "$(getprop ubootenv.var.digitaudiooutput)" = "SPDIF passthrough" ] ; then echo 1 > /sys/class/audiodsp/digital_raw elif [ "$(getprop ubootenv.var.digitaudiooutput)" = "HDMI passthrough" ] ; then echo 2 > /sys/class/audiodsp/digital_raw else echo 0 > /sys/class/audiodsp/digital_raw fi #echo 0 > /sys/class/graphics/fb1/blank #echo 1 > /sys/class/graphics/fb1/blank #fbset -fb /dev/graphics/fb1 -g 32 32 32 32 $osd_bits #echo 1 > /sys/class/graphics/fb1/blank #sleep 8 #echo m 0x1d26 '0x10b1' > /sys/class/display/wr_reg
i think i got it working
replace the following lines in your set_display_mode.sh script:
(begins at line 16)
Code:if [ "$(getprop ro.platform.hdmionly)" = "true" ]; then if [ "$hpdstate" = "1" ]; then outputmode=$(getprop ubootenv.var.hdmimode) setprop ubootenv.var.outputmode $outputmode else outputmode=$(getprop ubootenv.var.cvbsmode) setprop ubootenv.var.outputmode $outputmode fi else outputmode=$(getprop ubootenv.var.outputmode) fi
Code:if [ "$(getprop ro.platform.hdmionly)" = "true" ]; then if [ "$hpdstate" = "1" ]; then outputmode=$(getprop custom.hdmi.mode) if [ "$outputmode" = "" ]; then outputmode=$(getprop ubootenv.var.hdmimode) fi setprop ubootenv.var.outputmode $outputmode else outputmode=$(getprop ubootenv.var.cvbsmode) setprop ubootenv.var.outputmode $outputmode fi else outputmode=$(getprop ubootenv.var.outputmode) fi
Code:-> adb push set_display_mode.sh /mnt/scdard/ -> adb shell -> su $-> root@m0:/ # mount -o rw,remount -t rootfs rootfs /system/ $-> root@m0:/ # cp /mnt/sdcard/set_display_mode.sh /system/bin/
so now if you want to change resolution from 1080p to 720p type:
Code:root@m0:/ # setprop custom.hdmi.mode 720p root@m0:/ # sh /system/bin/set_display_mode.sh
Code:root@m0:/ # am display-size 1280x720
original:
Code:echo 0 > /sys/class/graphics/fb0/blank fi if [ "$(getprop ubootenv.var.digitaudiooutput)" = "SPDIF passthrough" ] ; then
Code:echo 0 > /sys/class/graphics/fb0/blank fi am display-size "$outputwidth"x"$outputheight" if [ "$(getprop ubootenv.var.digitaudiooutput)" = "SPDIF passthrough" ] ; then
4K: -> 3840x2160
4k2k24hz
4k2k25hz
4k2k30hz
4k2ksmpte
hdmi res:
(720x480)
480p
480i
480cvbs
(720x576)
576p
576i
576cvbs
(1280x720)
720p
720p50hz
(1920x1080)
1080p
1080i
1080i50hz
1080p50hz
If you mess something up, restarting your device should reset the resolution because the custom property is not persistent
you could theoretically update the script and extend some custom resolutions, nothing wrong should happen, because a restart resets the resolution.
but i wouldnt recommend that because i dont know what will happen if the resolution is not supported by the devices hardwareLast edited by feh; 21 May 2014, 11:04.
Originally posted by TMx View PostWe Definitely need a 3.10.33 Fix ...
XBMC should work on Both HD Ready (720) and Full HD TV sets Like 3.10.10
I believe the problem is it is detecting the capabilities of the TV and setting to 1080 if the TV supports it.
XBMC I cannot help with I am no XBMC expert. But I think first boot it needs to detect 720 not 1080 and set everything that way.
Suggestion. Try booting with NO HDMI cable plugged in. It should default to 720. Then once it is booted plug in your HDMI cable.
Just an idea.
Originally posted by NoSkillz View PostI don't understand why the keep releasing new firmware without this issue addressed. Basically makes XBMC useless for anyone who doesn't own a 1080 tv.
Originally posted by rlaursen View Postdisable auto detect and manually set your 720p tv to 1080i or 1080p in the android display settings. Surprisingly the 1080p selection works on my 720p tv and this resolves the xbmc issue.
However once you change it I noticed on my ROM that once you turn off CEC and set for 1280x720 sometimes the desktop will be screwed up. HOWEVER the important part is after a reboot it does boot into 2180x720 and the desktop is correct.
Users need to know this in settings.
1) Go to advanced and turn off CEC
2) The line below this turn off CEC button states what your set to. It does NOT look clickable like you can change it. BUT... if you click on it you can change your settings for the HDMI output. THIS IS NOW RETAINED ON EVERY BOOT UP!
Come on folks.... try this before asking for custom kernels.
Thanks rlaursen, makes me wonder what the problem is when I get so many weird responses, posted issue, etc etc... When I expect they know about this setting and I don't think it is clear they do!
Originally posted by Finless View PostI believe the problem is it is detecting the capabilities of the TV and setting to 1080 if the TV supports it.
Just an idea.
I don't think its XBMC related issue cos Same Application works Perfect on 3.10.10 and detects 720p Resolution without any special settings...
We don't need a Custom Kernel All we need is a Kernel that Combines both 3.10.10 and .33 features
Best Bet at the moment is 1080i cos I've checked wikipedia 720p Tvs has 1080i Resolution ...Last edited by TMx; 23 May 2014, 02:14.
Originally posted by TMx View PostI don't think its XBMC related issue cos Same Application works Perfect on 3.10.10 and detects 720p Resolution without any special settings...
Best Bet at the moment is 1080i cos I've checked wikipedia 720p Tvs has 1080i Resolution ...this is just an extra tv though.. i have a nice 125in projector hooked up to my M8
There are currently 2396 users online. 0 members and 2396 guests.
