M6 Mini PC TV-BOX AV Android 4.2 AML8726-MX , new out of box blank screen?
I don't think so, that a different rom helps... I had also much tobble with this SoC/Box at my TV and I also flash another rom but doesn't help... have a look at the link at the first post:
RK3288 Devices
- Overview BOX (LINK !)
Have you tried a different HDMI cable? What is the TV brand?
I haven't had any problems with any Amlogic boxes, whether M3 or M6 (dual core, MX...) unless you are connecting to a real old or not-so-well-made-store-brand TV. All the Amlogic devices run XBMC better than Rockchip, and you get much better performance with Linux than Android...
Sent from my TF300T using Tapatalk
Originally posted by kozmo2k4 View PostHave you tried a different HDMI cable? What is the TV brand?
Well, short of trying on a different monitor, one thing I would suggest: if the box is new, with no important user data on it, boot into recovery ("toothpick method" ) and Wipe Userdata and then Reboot. That may clear it up.
Sent from my TF300T using TapatalkLast edited by kozmo2k4; 18 May 2014, 21:39.
well, sorry to hear your problem.
we never met the same complaint before, each tv box have been tested before we ship to you, so there is image on our monitor before it leave our warehouse.
can you try on another tv or monitor, and let me know?
EricLooking for developers
As I wrote at #2 I didn't find a solution...RK3288 Devices
There are currently 2625 users online. 1 members and 2624 guests.
