HELP: MK908 doesn't boot. No LED lights after flashing stock ROM.
Hi. My MK908 suddenly started to fall into booting loop. So I flashed it with official stock ROM. Flashing worked well(at least Batch Tool 1.6 says SUCCESS & No errors). However, My MK908 doesn't boot and shows NO Signal. Blue LED lights doesn't turn on. Still I can connect it to PC and flash it. What's wrong? Please help. I'm a newbie. Thanks in advance.Tags: None
Originally posted by geek7319 View PostThanks for your advice.
However, unfortunately, it didn't work for me.
It flashes flawlessly with UPGRADE button as well but nothing changes.
Was your MK908's LED lights also dead? For me, I'm worrying about power circuit problem. Why no LED lights?
what version Mk908 do you have?
Originally posted by Ploggy View PostThe only time my mk908 had no led after a flash was if I flashed the wrong stock rom or kernal for my device.
Do I have to unbox it to find out the version? How?
Any advice is welcome.
Originally posted by geek7319 View PostI have no idea how to find out the version but I bought it as a new product recently. less than 1 month.
Yes, you have to remove the case to see what version you have, it's printed on the mobo.
Chances are if you recently purchased it it's probably a V5 like mine. If thats the case then this should work for you.
Hi guys: Here is the newest stock firmware for Tronsmart MK908, this firmware can work on V3 and V5 board. (V5 is the lastest board, and now all of the Tronsmart MK908 we shipped are V5 board). PS: how to check if you are V3 or V5 board, now the only method to check is […]
Remember to click upgrade to flash it
SOLVED:Thanks
Originally posted by Ploggy View PostYes, you have to remove the case to see what version you have, it's printed on the mobo.
Thanks everyone. I've solved the problem. Just flashed it with Finless ROM 1.8 and the blue LED is back. Finless Rom boots properly and I can use the device. Thank you.
Well, I have another question. How can I go back to the stock firmware. Just download stock rom and flash it with RK Batch tool 1.6 or 1.7? Do I need another procedure to go back to the stock rom?
Originally posted by geek7319 View PostThanks everyone. I've solved the problem. Just flashed it with Finless ROM 1.8 and the blue LED is back. Finless Rom boots properly and I can use the device. Thank you.
Yes, what you said is what you have todo.
Glad you got your device up and running.
There are currently 3251 users online. 1 members and 3250 guests.
