MK809 iii, New Model, I need the Firmware *Urgent*
Got a RS-232 working on it.
Installed the miniroot but with the HDMI not working I could not see any thing. So I hooked up a RS-232 to it. Had to solder. They make it easy with 3 points labeled RTG on the side.
Set it to 115200 baud rate. The 1ST time all the text came up.
But I can't type in it. I think it stops because no HDMI display. The last of the text looks like this:
Code:[ 8.037122] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 9.447041] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 10.187057] DWC_OTG: dwc_otg_hcd_enable, disable host controller [ 12.707122] hub 1-0:1.0: connect-debounce failed, port 1 disabled [ 17.307076] usb 1-1: new low speed USB device number 5 using usb20_otg [ 17.350766] DWC_OTG: DWC OTG No longer connected [ 17.351021] DWC_OTG: DWC OTG No longer connected [ 17.407121] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 21.637113] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 29.097114] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 33.847144] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 37.407092] usb 1-1: new low speed USB device number 9 using usb20_otg [ 37.476136] DWC_OTG: DWC OTG No longer connected [ 37.476390] DWC_OTG: DWC OTG No longer connected [ 37.527057] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 39.607093] usb 1-1: new low speed USB device number 10 using usb20_otg [ 40.212548] DWC_OTG: DWC OTG No longer connected [ 40.212799] DWC_OTG: DWC OTG No longer connected [ 40.267105] hub 1-0:1.0: unable to enumerate USB device on port 1 [ 42.717088] usb 1-1: new low speed USB device number 11 using usb20_otg [ 43.040114] DWC_OTG: handle_hc_chhltd_intr_dma: Channel 6, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000002, intsts 0x06000021 [ 57.847151] hub 1-0:1.0: unable to enumerate USB device on port 1
-Raymond Day
I got it to miniroot!
I flashed it again but this time used the parameter "serial console" downloaded from http://androtab.info/miniroot/ now I have to see if I can install ubuntu 14.04 server on it.
Here is how it came to the miniroot on the RS-232.
miniroot# [ 9.394418] DWC_OTG: dwc_otg_hcd_enable, disable host controller
miniroot# [ 17.184342] DWC_OTG: ********vbus detect******************************************** *
miniroot# ls
bin dev etc init lib mnt proc root sbin sys usr
miniroot#
-Raymond Day
Something is just wrong with mine.
The RS-232 worked on it good. But it would not see any USB things. So I gave up on it.
I did get another MK809III but this one don't look the same inside. The out side has the name of Android on it. The one talking about in here don't.
But found out from Google+ that can now boot right off a SD card. I did that with this bad MK809III and it would not go to were you can type. Just do a lot of text and reboot over and over.
But from Google+ I downloaded that image for the MK809III and did image to a SD card 16GB class 10 fast one. It boots super fast Ubuntu desktop and works super good.
On Google+ the link is here.
This is so super because it don't use the built in flash that has Android on it. It could even boot off the SD card with a bank flash in side it. It just don't use it at all. I guess that's what they did with the new ones.
This is super can take out the SD card and be back to Android.
The image just boots up fast and your in it.
I got a blue color HDMI stick it's 4 core 2GB RAM and it's the only one that the WiFi worked on.
Let me know if this works for you?
-Raymond Day
Any other working firmware for this board ?
After many tries I confirm only Finless rom is working on this stick.
it seems also the cpu is set to 1.2Ghz and not 1.4 like the others r3188t chips.
the only issue experienced with the Finless rom is that the Download manager is not opening and crash.\
Tried many changes without success.
More stable release of KK went out and I found a good and recent working release, but Wifi is not working.
What the KK rom are you using with this tv stick ?
Chris
There are currently 2359 users online. 2 members and 2357 guests.
