PMID701i battery issues
Originally posted by vannatte View PostI've already downloaded the airplane mode app and activated it. It doesn't seem to be helping the battery any. I've tried to find the Any Cut app to see where my battery is being eaten up, but it's not available on Google Play. Any recommendations?
I get about 3 hrs on mine with wifi and heavy use. You can try running the battery all the way down and charging it overnight. Sometimes the system may report it fully charged erroneously. Heard ICS gets better life. Anyone else?
Originally posted by matt View PostDon't remember where I. Got it. Try getjar 1mobile or blackmart (some pirated apps only download the free)
http://www.freewarelovers.com/android/app/any-cut
Originally posted by vannatte View PostAlso, when I go in to edit the phone.apk...it's already labeled something like "Old!Phone.old.apk". Not sure if I should change this or not.
The graph in the battery usage might be a false positive imo.
What kind of real world life are you getting? Turn off wifi and dim screen works best for me.
Need a test running video til low battery shutdown on reported full charge vs overnight charge. It may be subjective but it seems to last longer on overnight charge.
I wouldn't think the app would still have the apk extension if it had been disabled.
I keep hoping someone more qualified would weigh in, but they may all be playing with newer and shinier toys.
If you really need more battery life, there are auxiliary batteries for phones that could work. Duct tape one on! (Ha) (gub giggle under breath)
There are currently 3090 users online. 0 members and 3090 guests.
