I saw the problem with this S802 boxes- They get really hot and the performance drop :-(.
Have you mode the case to improve the cooling effect? - please share your mods :-).
I got the Tronsmart Vega Tronsmart Vega S89 Elite and it's really stupid design for it's SOC power.
It has no ventilation holes! -now I see more and more S802 devices getting problems because of the overheating- so I don't like to wait for the day it will die -this is why I thought about this Mod to make it look like Stock - adding 2mm spacer to the bolts hoes so I get 2mm gap between the bottom case to top case- 360 deg ventilation hole :-), the cold air will enter from lower front gap and exit from rear top gap :-) -what do you think?
