Pipo M7 Pro RileyROM 3.0 KitKat
    CAUTION: This IS a KitKat ROM...so do your homework on flashing KitKat ROM's before you get started.
    This ROM is based on official Pipo firmware that I ported from the M9 Pro dated 5/4/14 (still from beta testers, not from the Pipo site). Thanks to all of you users who saw this before I did. I've jumped ahead a couple of version numbers, because I actually had a couple of unreleased versions.
    One thing I have noticed is that QuickOffice now works and saves files to your SD card. We will have to wait and see what other fixes are in store.
    This ROM has all of the usual RileyROM features:
    Rooted
    Debloated
    Init.d support with Busybox commands
    English Default
    Google Play Store fixes
    Updated Google Apps
    2, 4, 6, 8 or 12gb user app space by selecting the desired parameter file
    Auto Install feature added for installing apk files on first boot from external SD
    TWRP recovery installed on first boot by Abdul_Pt
    Reboot app by Petrus
    New boot animation by me
    Latest revision of the First Time User's Guide
    Flash Tool by Finless
    All made with a variation of 900SuperSport's Freaktab Kitchen
    Edit: This is now v3.0.1 with fixes to Exchange Server email.
    Download
    Please donate to support RileyROM's on Freaktab.
    Randy
    Just a note about QuickOffice.
    The factory version that comes on this ROM works. If you allow Play Store to update it....it will not work anymore. Don't allow automatic updates on QuickOffice.
    You can go into apps and uninstall the update and it will work again....if it does update on you. Another example that newer isn't necessarily better.
    Randy
      May I ask what's new here??
        Rooted
        Debloated
        English Default
        Updated Google Apps
        Download
        May I ask sir randy what's new here? Thank you 👈👍👍
          New FW Released in Pipo Website
          New FW dated 05-26-2014
          M7pro#128_892_EN.img
          Proud M7Pro owner and Freaktab fan
            Hi, Do you know if this is a Kitkat rom?
              Nevermind, I can confirm that this NOT Kitkat. Will be flashing Riley's 3.0 now.
                Please give us some feedback once you flashed, I'm very curious. Also, to know whats new and if it pays off to update from 2.7. would be great.
                thanks
                  Yes...this is KK based on the firmware for the M9 Pro. Since I use my M7 Pro to test my M9 Pro ROMs, I decided to publish it for the M7 Pro. Anna at Pipo replied last week that there were no plans for an M7 Pro Update.
                  Unfortunately, Pipo doesn't give release notes.
                  BTW...I didn't mention that I'm using the kernel from the 2.8 ROM in this one.
                  Randy
                    M9 pro 2014_05_24, official Chinese: http://pipo.cn/En/index.php?m=About&...an_show&id=185
                      Yes, we have been talking about that over on the M9 Pro thread. I'm going to take a look at this and will likely make a ROM from it, too. I've read that this one isn't as stable as the one I made THIS ROM from. We shall see.
                      Randy
                        I'm thinking logically here...I could stand corrected, but it appears that the main difference between the two M9 Pro ROM's I'm working with are the kernel versions.
                        Since I'm not even using the M9 Pro kernels in the M7 Pro ROM's, I'm not sure there's any REAL difference. I'm adding the kernel from my 2.8 ROM in both ROM's.
                        Just in case you want to try, I'm providing an alternative ROM...v3.1. I will post a link as soon as I get it uploaded.
                        Randy
                          any chance you can make OC kernel for pipo m9 pro
                            There's a thread for that in the main Pipo forum. I will let the kernel guys take care of that. They are much better at it than I am.
                            Randy
                              oh yeah 1 more question wich govenor is best for balance between performance and battery?
