Pipo M7 Pro RileyROM 3.0 KitKat
Again, it's best to ask the kernel guys....I pretty much run stock kernels.Randy
Here is the new thread for v3.1...based on an updated Pipo (Official, this time) release for the M9 Pro.
I really doubt if there is any difference between 3.0 and 3.1. The M9 Pro firmware had a newer kernel in the update, but I'm still using the same kernel from the 2.7 and 2.8 ROM's in both 3.0 and 3.1.
Randy
Hi!
Thank you rrileypm for your great work!
I received my PiPo M7 Pro Wi-Fi today, and already installed your ROM, 5 stars!
But i have one problem (ok, two, camera bug..), i cant use my External SD ... 32GB .. What i need to do to activate it? i can see it in settings, but cant use it..
And after a deep sleep, it shows a notification, that SD card can be securily removed ..
Hope you can help me
I will have to test that on my tablet and see what's going on.Randy
Thanks for the work put into the ROM, Riley. I've been flashing every single one that's been put out for the M7Pro (almost flashed the 3.1 as well). I'm a complete novice, so its difficult for me to comment on the improvements, but it's definitely more stable (no reboots so far), and much smoother. The only challenge that I've been having with all the kitkat roms (2.7, 2.8 and 3.0) is GPS. Can't seem to get a fix on the satellites with GPS test. It sees only 2-3 satellites (poor signal) after about 2 minutes, and non in use. When using Google maps, 'waiting for location' is the message everytime you try to click on the own location button. Do you know if its just my tablet or is everyone facing the same issue? No biggie for me, as I hardly use the GPS function, just good to know that we can use everything that comes with the tablet
BTW, I've also tried activeGPS app as suggested in the 2.8 thread, but doesn't seem to solve it for me.
Once again, thanks a mil for the ROMs, Riley.
You might need to check the external SD for errors in Windows.Randy
I have been testing my tablet....no SD card problems...not problems with root...I can't connect to my hotmail account either.Randy
I'm also having the camera issue. As I get time, I will try to port the camera drivers over from a previous rom and see if I can get it working.
It seems like I've sat in front of a computer for the last week non stop. Time for a little break.Randy
That seems to be a problem on these latest KK firmwares from Pipo. Its also happening on the U8 ROM.Randy
There are currently 2585 users online. 0 members and 2585 guests.
