I've got the Problem that if I play any 1080p .mkv/.mts File in XBMC it stops after some seconds an starts buffering....than stops again...buffering...and so on
.gif)
If I browse to the Movies through the ES File Explorer and start it with XBMC it rans smoothly
These Files are on an SMB Folder (LAN Connection).
Perhaps any Buffering Tweaks that I have to make?
I used ACEMAX 20140516 (rooted) with Oman's XBMC.
Tested Tronsmart XBMC RC also as some Nightlies also the Finless Rom, nothing changed.
Second Question: Any "easy" Solution to run Stock XBMC with Hardware Decoding?
Greets
