Maybe just paranoid with my new toy, but is that normal? If you connect in recovery mode to a PC and leave it for a minute or two does it just timeout and disconnect on its own? Thanks for any info!
Quick question from a new (paranoid) Minix Neo X7 user
I just received the unit and flashed the 3.1 Nitro Rom tonight. One oddity was the fact that when I initially connected to a PC and held in the recovery button, it connected and I installed the drivers. Afterward, I rebooted (as it says everywhere to reboot afterward) and reconnected again. I was about to flash the rom, but had to run into the other room for something. After about a minute, I heard the tone of the USB disconnect. I came back out and the Minix was no longer detected by the OS. I had to remove power, plug it back in and push the recovery button again to allow it to reconnect. I flashed the rom without issue afterward.
Maybe just paranoid with my new toy, but is that normal? If you connect in recovery mode to a PC and leave it for a minute or two does it just timeout and disconnect on its own? Thanks for any info!Tags: None
Originally posted by zektor View PostI just received the unit and flashed the 3.1 Nitro Rom tonight. One oddity was the fact that when I initially connected to a PC and held in the recovery button, it connected and I installed the drivers. Afterward, I rebooted (as it says everywhere to reboot afterward) and reconnected again. I was about to flash the rom, but had to run into the other room for something. After about a minute, I heard the tone of the USB disconnect. I came back out and the Minix was no longer detected by the OS. I had to remove power, plug it back in and push the recovery button again to allow it to reconnect. I flashed the rom without issue afterward.
some users had the same issue.
if all went fine -> then fine ^^
if not ->> reflash but this time pls hold the needle or whatever u are using to push the resetbutton on the minix all the time the minix is flashing.
-->> ALL THE TIME ^^
then the minix wont reconnect or disconnect itself from the pc.
when the minix is 100% flashed then and ONLY then u can put the needle away from the resetbutton
give it a try
There are currently 4560 users online. 0 members and 4560 guests.
