well i dont no but i never conect my box to a blueray player eny way mate. sorry. i no the new finless rom works on it though. hell of a job finless bob has done on this rom.
MBOX S82B Amlogic S802-B
Originally posted by dankec View PostSo, then it is completely the same... I mean, if everything works fluid I don't care if it's hardware or software decoding. Great, I'm taking this device... Thx
Dolby Digital encodeing
Apologies for digging up an old thread . I am investigating the Digital out put of the S82B , Currently I have been unsucessfull of recieving any signal at all from the device .
I have the 111K4 2.1 Finless ROM
My DTS/Dolby amp is hooked up but is not recieiving anything at all , I have tried Dolby encoded media in MXplayer and PCM encoded media through XBMC
Hi..9090
Have you tried..changing android settings,
Desktop-mbox settings-advanced
-disable audio auto-detection
Then change: digital audio output
In kodi/xbmc/spmc set passthrough on
System-settings-system-audio output
-enable ''settings level' to advanced
Then change/enable passthrough dolby/dts
Goodluck
digital out through optical
Goodluck
Thanks Mitch
Yes all is now working , just watched Tron with vitual surround on xbmc , sound was crisp . However the option to change the audio option to Dolby/spdif passthrough was originally locked (fresh ROM flash) this option could only be changed after the MX player was installed. My theory is that MX player contains codecs which fire up the opitical port ...
Happy new year
There are currently 1337 users online. 0 members and 1337 guests.
