[ROM] Quickshot V3.1 for minix X7 mini
    THe NiTRo TeaM PreSeNTs
    *****QuickShoT v3.1*****
    Quickshot 3.1
    Changelog:
    - KiTKaT!!
    - Custom Kernel 1080p by default
    - Built from sources
    - Rooted
    - Busybox updated
    - All the google apps up to date.
    - Added init.d support
    - adb by tcp ( wifi or ethernet) by default
    - Nano editor added
    - Tcp tweaks added
    - Minix Launcher MOD by NitroTeaM
    - Dolphin as default browser. We did this because is the only one that supports flash in a usable way in kitkat. Remember to turn on the plugin, is disabled by default.
    - Apps Preinstalled: EsFileExplorer, Mxplayer, Dolphin, Tincore Keymapper, Reboot, xbmc gotham, adblock, terminal emulator, Sony Walkman, ehomemediacenter, flash player hacked, etc... All the apps are installed as user so you can uninstall the ones you don't like
    - QuickFlasher and Keymapper from Tincore
    - Support for some flymouse, f10, f10pro, i25..etc
    - Setup Wizard added
    - SmartTV sytle mouse pointer
    - Minix Launcher modded by us
    - TWRP recovery is automatically installed on first boot. Thanks to Abdul-pt (Freaktab)
    - Quickshot-Update system. This was introduced on V2 as an easy update method, you just need to copy the update files we provide under /sdcard or on your "real" sd-card and reboot.
    - A2 remote sound will not used by default.
    - libmedia.so hacked by wasser (freaktab). Now we can enjoy dolby and DTS passthrough in XBMC too. Thanks a lot to wasser for share it.
    - A2 remote key mapped correctly. Thanks a lot to casadroide (androidPC.es) for it.
    - New XBMCZ compilation by jmcm66 based in XBMCZ 13.1. Modded by TNT.
    - New nfs and smb scripts in init.d, to mount your network points automatically in each reboot. You need to edit them to activate.
    - A ton of kernels, 1080p/720p with several different overclock values. Remember, Overclock can damage your system, you use this at your own risk. We do this all the time As a plus, if you flash a 720p kernel the "small icons" patch is applied automatically, and if you flash a 1080p kernel then "big icons" patch is applied. This works for both methods, quickshot-update and quickflasher.
    - Some other Tweaks
    - Clear ALL Button added to the tasks manager, you can see it on top right of the screen.
    - xbox360 pad patch made by Casadroide from Androidpc.es
    - NFS example script included under /system/etc/init.d , just edit to suit your needs and you will have your nfs or samba shares mounted every boot.
    Kernel V3.1 Features:
    -24Hz added if your TV support it.
    -Some minor bugs Fixes.
    -HDMI values adjusted.
    -USB OTG port selected in host mode by default.
    -RK3188T proccessors unlocked and identified in dmesg.
    -NTFS and ExFat support added in kernel.
    -SMB and NFS support built in kernel.
    -DTS and AC3 passthrough support. (Not in XBMC yet)
    -Added new governors and IOSchedulers.
    -Device LED working.
    -You can choose between real 720p or real 1080p kernels.
    -Various overclocking values: Select them using a kernel name with:
    cpuxxxx: xxxx is cpu speed Ej:cpu1608 is cpu at 1608 MHz
    ddrxxx: xxx is DDR speed Ej: ddr667 is DDR at 667 Mhz
    gpuxxx: xxx is GPU speed, and "h" behind is that only high speed steps are enabled:
    gpu600: speed values from 133MHz to 600Mhz.
    gpu600h:speed values from 400MHz to 600Mhz.
    gpu798: speed values from 266MHz to 798Mhz.
    gpu798h:speed values from 600MHz to 798Mhz.
    Take care if you want to come back from loader 2.xx (kitkat) to Loader 1.xx (Jellybeans) You can brick your device.
    See:
    Known bugs in QS3.1 (working on them):
    - On some TV screens and with certain HDMI cables you can see a 1 second screen blackout in certain circunstances. (Try other HDMI cables to solve it)
    - Stock Launcher bugs (we recommend to use Nova Launcher or other one):
    - Launcher Bug The quick launcher icons (lower side of the screen) are not centered when using small icons on 1080p kernels
    - Launcher Bug The first time you run dolphin from the quick launch icon, the shortcut jumps to desktop and you have to move it to its place again. It looks like the dolphin jumps out of the fish tank xD
    - On some screens you can see a 1s blackout in certain circumstances
    Thanks to
    To MSX2 and ZX81, administrators from http://androidpc.es/
    To all people here in freaktab.com.
    To Minix for its colaboration.
    To abdul_pt for its great TWRP
    To Petrus for its reboot app
    To d33 and wasser for their great help with the kernel
    To Casadroide from http://androidpc.es/ por its xbox pad patch
    To SoulStyle for its nfs script
    To jcmcm66 for the xbmcz.
    To Superatmel from the Superteam
    To our betatesters:
    - Casadroide from http://androidpc.es/
    - Akinator from Forocoches
    - Ciberus from Forocoches
    - Rdsok from Freaktab
    - JDFense from Freaktab
    - oldfart101 from Freaktab
    - franckleroy from Freaktab
    - sonoman from Freaktab
    - servo386 from freaktab
    IF YOU WANT TO BUY US SOME COFFEE OR BEER
    My devices:
    Gearbest.com)
    DOWNLOADS:
    CUSTOM ROM QS 3.1 TO FLASH FROM PC (drivers included): (Look at 3º post for precise instructions.)
    MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
    md5 639f91e6e9dffadb4efe8eb4e3fe085b
    KERNELS PACK
    There are 2 ways to install the kernels, using QUICKFLASHER or QUICKSHOT-UPDATE (Look at 3º post for precisse instructions.)
    When you flash a 720p kernel small icon patch will be applied automatically and when you flash a 1080p kernel the big icons patch will be applied. Remember that 720p kernels needs always small icons patch to work properly.
    KERNELS PACK 1080p WITH DIFFERENT OVERCLOCK FOR QUICKFLASHER
    https://mega.co.nz/#!eBUCWS7R!wP0ZRs...60m6zlcGKqLiq0
    md5 d23e6f11d71ca7e877b12ce315016205
    KERNELS PACK 720p WITH DIFFERENT OVERCLOCK FOR QUICKFLASHER
    md5 8f1b9bad27f6811c7cf22f609f0e1f6f
    KERNELS PACK 1080p WITH DIFFERENT OVERCLOCK FOR QUICKSHOT-UPDATE
    md5 3953a3eeb6885c43f2d110aed5447d67
    KERNELS PACK 720p WITH DIFFERENT OVERCLOCK FOR QUICKSHOT-UPDATE
    md5 9979aa46ff210273348dd335505819e9
    If you have a 1080p kernel you can apply big icons or small icons patch, in 720p only small icons are allowed(it looks like big icons in 1080p).
    Kernel packs for people with flickering problems(use them only if you experience flickering problems) :
    kernel-pack at 1080p for quickflasher:
    https://mega.co.nz/#!nd8gjbzY!fp5dzj...GvJ8MLGOxaEKFQ
    kernel-pack at 720p for quickflasher:
    https://mega.co.nz/#!eNsR2QJQ!RqT4vj...CqnVLuZmmPh-U8kernel-pack at kernel-pack at 1080p for quickshot-update:
    kernel-pack at 720p for quickshot-update:
    Small Icons Patch
    or
    HERE
    md5 dc308d369dee4aa4e10c8e2f7d64e639
    Big Icons patch
    or
    HERE
    md5 fef2abb424526c2e83abd227e0824bb3
    Deleted Rockchip apps if someone wants to install them
    or
    HERE
    md5 06ee1db5f25fd4bbe82094449ffeffdc
    WINDOWS APP TizzNFS, to create nfs mount point easy
    or
    HERE
    md5 da7c9dc1cca712646a553e5288a30c60
    DRIVERS , Inside the rom flasher there are drivers included but anyway we let you this automatic installer
    or
    HERE
    md5 93908750eaf57b7be9af3247722a9dd7
    There are 10 types of people in the world: Those who understand binary, and those who don't...
    If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
      CONFIGURATION RECOMENDATIONS:
      Go to settings, in WiFi section, if you use wifi, we recommend that you press the 3 dots points that appear in the top right of the screen, select Advanced settings and deactivate WIFI optimization, our Android tvbox uses no battery and it is better to have wifi to 100% always.
      -Please do the same with Ethernet, if you don't use it, disable it.
      -In the screen section, you can set multiple values, in scaled screen we must adjust the bar to match the edges of our android system with our TV or screen.
      -if we want an icon for screenshot in our system tray we can activate it in settings/screenshotsettings.
      -in the applications section, we have all that come installed with the rom, we have included the apps we consider essential, but are all as user applications, so if them bother you, you can remove them without problems.
      -In language and text input, we have a couple of options that we recommend, Tincore Key-mapper, to configure your input devices: pads, joysticks, air-mouse, keyboards, etc... and NULL INPUT METHOD, a very useful application that prevents Google Keyboard to be displayed if you're using external keyboard. By default, I advise you to install any of these two. Also if you use external keyboard we recommend to try apps like "external keyboard helper".
      - ADBlock is preinstalled and up to date, but disabled by default. If you want ads to be blocked, open the app and activate it.
      - Flash plugin is disabled by default on Dolphin, to activate it you have to click on the dolphin icon that is beside the address bar, then a window comes up, click on the very first icon on upper left, then Web content-->Flash Player and set it to Allways on.
      - If you use the nfs example script in init.d, after editing to suit your needs remember to set the executable bit because is disabled by default.
      INSTALL FROM WIN XP/7:
      INSTALL IT USING THE OFFICIAL METHOD
      USING QUICKSHOT-UPDATE.ZIP METHOD TO APPLY PATCHES OR TO FLASH KERNELS (noobs friendly method)
      Step 1. Download the special quickshot-update kernel pack you like more, there are two, 720p and 1080p.
      Step 2. Open the zip file, you will see some folders inside. The name of this folders correspond to the properties of the kernel inside.
      Step 3. Open the folder you like more and you will see a quickshot-update.zip file inside, copy that file to a (real) sd card (fat32 formatted) or copy it to the internal memory under /sdcard/
      Step 4. Reboot (not power off, just reboot) and wait.
      Step 5. Done! Your kernel is flashed and the corresponding icons patch is automatically applied. If you used a real SD card (not the internal memory) remember to pull out the card when done and delete the file.
      HOW TO USE QUICKFLASHER TO FLASH PATCHES OR KERNELS
      HOW INSTALL NON COMPATIBLE APPS FROM MARKET USING MARKET HELPER:
      BUY US SOME COFFEE
      Thank you for buying me a beer
        Yea, but are you going to be releasing this for the mini?
        Haha, sorry lads couldn't resist.. Good work.
        To Infinity and Beyond.... XBMC
          Yes we will release it
          We don have the mini device and we need to ask betatesters about the result, and if we got some problem reported back we try to fix it, but without the device is hard to do that
          leolas
          My devices:
          Gearbest.com)
            Re: [ROM] Quickshot V3.1 for minix X7 mini
            leolas
            LOL
              WIFI problem with NEWMinix NEO X7mini (with antenna)!!!
              Great work Nitro Team!!!
              I have the latest X7 mini (with antenna) and unfortunately the WIFI does not work!! (I cannot enable it).
              http://www.****.com/itm/281321843243...84.m1497.l2649
              I don't know if the model with antenna has a diffrent wifi chipset... Or even if it has any diferrence at all from previous x7 mini besides the external antenna.
              While Quickshot v2 worked just fine...
              Any ideas?
              Thanks in advance
                Originally posted by bluechris View Post
                Any ideas?
                Thanks in advance
                try to flash again, ensure you download the proper file, and please report back
                  https://mega.co.nz/#!WJlShIoB!84nZZl...orSSbbuP74fQCE
                  Very interesting I flashed again the v3.1 and this time WIFI worked!!!
                  The only difference was that during install wizard I left English as default language instead of changing it to Greek...
                  Could this be the glitch?
                  Anyway everything went fine!!!
                  Excellent FW by first look and a huge leap from v2.
                  Great work Nitro Team!!! You Rock!!!
                  Thank YOU!!!!
                    Thank YOU!!!!
                    Language must have nothing to do with WiFi, maybe a bad flash?
                    sent by my phone.
                    enviado desde mi teléfono.
                    leolas
                    My devices:
                    Gearbest.com)
                      5.1 passthrough in XBMC via HDMI?
                      removed. wrong thread
                        sent by my phone.
                        leolas
                        The result was succeded ok both times...strange...
                            great rom!! fast stable so far only problem really bad playback using mxplayer pro....
                            stutters and sound (passtrough spdif) have small gaps sounds pops out and on my receiver the signal is gone for a milisecond.. happens allot
                            greetz giorgio
                              OMG
                              Originally posted by LCBXX View Post
                              You guys Rock.. Now if only you could put clockworkmod into the base kernel so I can do full system images without having to install it...
