[ROM] Quickshot V3.1 for minix X7 mini
    Originally posted by sabrezn View Post
    Hey guys, so I am still learning and not to hot on this stuff. I am running quickshot 2 on my minix x7 mini.
    If I update to quickshot 3 will my xbmc Library be deleted and I then have to re add all my subscriptions and video files.
    Also is there away to run games/apps off my external SD card as the internal space in minuscule.
    Shot guys I appreciate the help.
    Jarrud
    Yes, when you flash 3.1 or 3 all your entire nand will be erased.
    Originally posted by giorgios View Post
    hello guys tried this rom flashed multiple times but major video playback issues.. is there a way to flash back to quickshot 2 jb works better for me
    thanks
    We don't have the mini, we have the Neo X7 with a power button, we can explain step by step how to come back in the devices we have Unfortunately we cant explain it in a device we don't own, In first post you have a link to a rriley post where he explain now come back from kitkat to jb, this instructions are more generic, but is the most we can do.
    leolas
    My devices:
    Gearbest.com)
      In your flashtool is no Erase button, so we dont come back to JB ??
      In the Post from rrileypm he writes we must erase with the 4.4.2 Flashtool, but in the Flashtool is no Erase button! I need a Flashtool from a 4.4.2 ROM with a Erase button, because i want back to QS v2.0 this ROM is much better than this here.
      ... TVDroid
      > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
        The tool is the same that we use in qs2, I included the loader to make it easy. Remember that I never test this way to return to jb in the mini.
        leolas
        My devices:
        Gearbest.com)
          Ok i dont want a brick.
          I love my Device... but XBMC is slow and i dont have a Softbutton for Volume and the Mouse Cursor i dont like... all this was much better in QS v2.0.
          ... TVDroid
            Hello
            you do not believe me I took the risk and I managed to go back to JB.
            I used the package QS V2 as a tool and I followed the tutorial here: http://www.freaktab.com/showthread.p...back+jellybean
              I try it like you and now i got a FAIL !!!
              Now is my Device in MaskROM MODE... EDIT: Ok with BatchTool 1.7 and the update.img from QS 3 i got my Device back to life... but only on KitKat... i try all but i cant go back to JB.
              ... TVDroid
                Have you done a erase IDB in the first place?
                  Yes i do exacly what in the HowTo is.
                  1. Erase with the Tool from Posting #108 from leolas.
                  2. Open QS 2.0 Flashtool and press only RUN.
                  ... than Error !
                  ... TVDroid
                    Originally posted by leolas View Post
                    www.freak-tab.de/leolas/kk-flash-tool.zip
                    leolas
                    leolas,
                    I'm going to ask a question out of ignorance for the process... so beware
                    I don't see a parameter file in that download... should there be one so it describes the IDB for the QS3/3.1 ROM in order that it can properly erase the IDB for a KK ROM... or is that covered in the config.cfg or settings.ini?
                      Re: [ROM] Quickshot V3.1 for minix X7 mini
                      Originally posted by rdsok View Post
                      leolas,
                      maybe you are right, I didn't though on that. Thanks a lot rdsok, tomorrow I will upload it.
                      sent by my phone.
                      enviado desde mi teléfono.
                      leolas
                      My devices:
                      Gearbest.com)
                        Nevermind on the previous bug report regarding my remote stopped working after a factory reset. I reflashed the rom and the remote still does not work. The remote apparently "died" coincidentally after I factory reset the rom, but the rom was not the problem. Just a faulty remote.
                          Make certain you downloaded the proper ROM for yours... They have a Minix Neo x7 as well as the mini version and they are not interchangeable
                          Thank you very much for this fantastic and smooth ROM !
                          Reading through the post it seems like i am not the only one having issues with WIFI - here's my story:
                          I am using a Minix x7 *mini* and have downloaded the ROM from both mirrors:
                          Have flashed over 5 times - on the RKDevice Manager Tool - tried leaving English / Spanish -
                          nothing seems to work.. no wifi
                          any suggestions or fixes available?
                          thank you for all of your continuous hard work!
                            Have you tried to disable ethernet?
                              Yes
                              Both physically and software
                              wifi can't even startup - tries to initiate and after 20 sec fails and repeating this does not help either
                              Any other suggestions?
                              Thanks in advance
                                Yes
                                Thanks in advance
                                There is someone more with this problem in the mini?
                                sent by my phone.
                                leolas
                                My devices:
                                Gearbest.com)
