[CUSTOM ROM] QuickShoT v3.1 for cr11s with ap6210 and 5Mpx camera
    THe NiTRo TeaM PreSeNTs
    *****QuickShoT v3.1 for cr11s with ap6210 and 5Mpx camera*****
    Quickshot 3.1
    Changelog:
    - KiTKaT!!
    - Custom Kernel 1080p by default
    - Built from sources
    - Rooted
    - Busybox updated
    - All the google apps up to date.
    - Added init.d support
    - adb by tcp ( wifi or ethernet) by default
    - Nano editor added for terminal emulator.
    - Tcp tweaks added
    - Dolphin as default browser. We did this because is the only one that supports flash in a usable way in kitkat. Remember to turn on the plugin, is disabled by default.
    - Apps Preinstalled: EsFileExplorer, Mxplayer, Dolphin, Tincore Keymapper, Reboot, xbmc gotham, adblock, terminal emulator, Sony Walkman, ehomemediacenter, flash player hacked, etc... All the apps are installed as user so you can uninstall the ones you don't like
    - QuickFlasher and Keymapper from Tincore
    - Support for some flymouse, f10, f10pro, i25..etc
    - Setup Wizard added
    - SmartTV sytle mouse pointer
    - TWRP recovery is automatically installed on first boot. Thanks to Abdul-pt (Freaktab)
    - Quickshot-Update system. This was introduced on V2 as an easy update method, you just need to copy the update files we provide under /sdcard or on your "real" sd-card and reboot.
    - A2 remote sound will not used by default.
    - libmedia.so hacked by wasser (freaktab). Now we can enjoy dolby and DTS passthrough in XBMC too. Thanks a lot to wasser for share it.
    - A2 remote key mapped correctly. Thanks a lot to casadroide (androidPC.es) for it.
    - New XBMCZ compilation by jmcm66 based in XBMCZ 13.1. Modded by TNT.
    - New nfs and smb scripts in init.d, to mount your network points automatically in each reboot. You need to edit them to activate.
    - A ton of kernels, 1080p/720p with several different overclock values. Remember, Overclock can damage your system, you use this at your own risk. We do this all the time As a plus, if you flash a 720p kernel the "small icons" patch is applied automatically, and if you flash a 1080p kernel then "big icons" patch is applied. This works for both methods, quickshot-update and quickflasher.
    - Some other Tweaks
    - Clear ALL Button added to the tasks manager, you can see it on top right of the screen.
    - xbox360 pad patch made by Casadroide from Androidpc.es
    - NFS example script included under /system/etc/init.d , just edit to suit your needs and you will have your nfs or samba shares mounted every boot.
    Kernel V3.1 Features:
    -24Hz added if your TV support it.
    -Some minor bugs Fixes.
    -HDMI values adjusted.
    -USB OTG port selected in host mode by default.
    -RK3188T proccessors unlocked and identified in dmesg.
    -NTFS and ExFat support added in kernel.
    -SMB and NFS support built in kernel.
    -DTS and AC3 passthrough support. (Not in XBMC yet)
    -Added new governors and IOSchedulers.
    -Device LED working.
    -You can choose between real 720p or real 1080p kernels.
    -Various overclocking values: Select them using a kernel name with:
    cpuxxxx: xxxx is cpu speed Ej:cpu1608 is cpu at 1608 MHz
    ddrxxx: xxx is DDR speed Ej: ddr667 is DDR at 667 Mhz
    gpuxxx: xxx is GPU speed, and "h" behind is that only high speed steps are enabled:
    gpu600: speed values from 133MHz to 600Mhz.
    gpu600h:speed values from 400MHz to 600Mhz.
    gpu798: speed values from 266MHz to 798Mhz.
    gpu798h:speed values from 600MHz to 798Mhz.
    Take care if you want to come back from loader 2.xx (kitkat) to Loader 1.xx (Jellybeans) You can brick your device.
    See also:
    Known bugs in QS3.1 (working on them):
    - On some TV screens and with certain HDMI cables you can see a 1 second screen blackout in certain circunstances. (Try other HDMI cables to solve it)
    - Stock Launcher bugs (we recommend to use Nova Launcher or other one):
    - Launcher Bug The quick launcher icons (lower side of the screen) are not centered when using small icons on 1080p kernels
    - Launcher Bug The first time you run dolphin from the quick launch icon, the shortcut jumps to desktop and you have to move it to its place again. It looks like the dolphin jumps out of the fish tank xD
    Thanks to
    To MSX2 and ZX81, administrators from http://androidpc.es/
    To all people here in freaktab.com.
    To abdul_pt for its great TWRP
    To Petrus for its reboot app
    To d33 and wasser for their great help with the kernel.
    To Casadroide from http://androidpc.es/ por its xbox pad patch
    To SoulStyle for its nfs script
    To jcmcm66 for the xbmcz.
    To Superatmel from the Superteam
    To our betatesters:
    - Casadroide from http://androidpc.es/
    - Akinator from Forocoches
    - Ciberus from Forocoches
    - Rdsok from Freaktab
    - JDFense from Freaktab
    - oldfart101 from Freaktab
    - franckleroy from Freaktab
    - sonoman from Freaktab
    - servo386 from freaktab
    IF YOU WANT TO BUY US SOME COFFEE OR BEER
    My devices:
    Gearbest.com)
    DOWNLOADS:
    CUSTOM ROM QS 3.1 TO FLASH FROM PC (drivers included) CLEAN INSTALL (RECOMENDED): (Look at 3º post for precise instructions.)
    MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
    md5 0acb86adab88860e2d5d92f20693c078
    KERNELS PACK
    There are 2 ways to install the kernels, using QUICKFLASHER or QUICKSHOT-UPDATE (Look at 3º post for precisse instructions.)
    When you flash a 720p kernel small icon patch will be applied automatically and when you flash a 1080p kernel the big icons patch will be applied. Remember that 720p kernels needs always small icons patch to work properly.
    KERNELS PACK 1080p WITH DIFFERENT OVERCLOCK FOR QUICKFLASHER
    KERNELS PACK 720p WITH DIFFERENT OVERCLOCK FOR QUICKFLASHER
    md5 ff8a58c6bd0b6bd62e24a09cc57c21e7
    KERNELS PACK 1080p WITH DIFFERENT OVERCLOCK FOR QUICKSHOT-UPDATE
    md5 b30c71162b1b0354a54df0e05540af18
    KERNELS PACK 720p WITH DIFFERENT OVERCLOCK FOR QUICKSHOT-UPDATE
    md5 2cd11bfc1a11306c1f259c211ac56242
    If you have a 1080p kernel you can apply big icons or small icons patch, in 720p only small icons are allowed(it looks like big icons in 1080p).
    Small Icons Patch
    or
    HERE
    md5 dc308d369dee4aa4e10c8e2f7d64e639
    Big Icons patch
    or
    HERE
    md5 fef2abb424526c2e83abd227e0824bb3
    Deleted Rockchip apps if someone wants to install them
    or
    HERE
    md5 06ee1db5f25fd4bbe82094449ffeffdc
    WINDOWS APP TizzNFS, to create nfs mount point easy
    or
    HERE
    md5 da7c9dc1cca712646a553e5288a30c60
    DRIVERS , Inside the rom flasher there are drivers included but anyway we let you this automatic installer
    or
    HERE
    md5 93908750eaf57b7be9af3247722a9dd7
    There are 10 types of people in the world: Those who understand binary, and those who don't...
    Thank you for buying me a beer
      CONFIGURATION RECOMENDATIONS:
      Go to settings, in WiFi section, if you use wifi, we recommend that you press the 3 dots points that appear in the top right of the screen, select Advanced settings and deactivate WIFI optimization, our Android tvbox uses no battery and it is better to have wifi to 100% always.
      -Please do the same with Ethernet, if you don't use it, disable it.
      -In the screen section, you can set multiple values, in scaled screen we must adjust the bar to match the edges of our android system with our TV or screen.
      -if we want an icon for screenshot in our system tray we can activate it in settings/screenshotsettings.
      -in the applications section, we have all that come installed with the rom, we have included the apps we consider essential, but are all as user applications, so if them bother you, you can remove them without problems.
      -In language and text input, we have a couple of options that we recommend, Tincore Key-mapper, to configure your input devices: pads, joysticks, air-mouse, keyboards, etc... and NULL INPUT METHOD, a very useful application that prevents Google Keyboard to be displayed if you're using external keyboard. By default, I advise you to install any of these two. Also if you use external keyboard we recommend to try apps like "external keyboard helper".
      - ADBlock is preinstalled and up to date, but disabled by default. If you want ads to be blocked, open the app and activate it.
      - Flash plugin is disabled by default on Dolphin, to activate it you have to click on the dolphin icon that is beside the address bar, then a window comes up, click on the very first icon on upper left, then Web content-->Flash Player and set it to Allways on.
      - If you use the nfs example script in init.d, after editing to suit your needs remember to set the executable bit because is disabled by default.
      INSTALL FROM WIN XP/7:
      Use the standard manufacturer way to install the rom.
      USING QUICKSHOT-UPDATE.ZIP METHOD TO APPLY PATCHES OR TO FLASH KERNELS (noobs friendly method)
      Step 1. Download the special quickshot-update kernel pack you like more, there are two, 720p and 1080p.
      Step 2. Open the zip file, you will see some folders inside. The name of this folders correspond to the properties of the kernel inside.
      Step 3. Open the folder you like more and you will see a quickshot-update.zip file inside, copy that file to a (real) sd card (fat32 formatted) or copy it to the internal memory under /sdcard/
      Step 4. Reboot (not power off, just reboot) and wait.
      Step 5. Done! Your kernel is flashed and the corresponding icons patch is automatically applied. If you used a real SD card (not the internal memory) remember to pull out the card when done and delete the file.
      HOW TO USE QUICKFLASHER TO FLASH PATCHES OR KERNELS
      HOW INSTALL NON COMPATIBLE APPS FROM MARKET USING MARKET HELPER:
      BUY US SOME COFFEE
      If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
        good job guys
        thanks to the nitro team for this great rom
        MK808B K.I.A.
        MK908 Finless ROM 1.7a + Mele F10
        CR11S Quickshot V3.1, 720p kernel @1,7GHz, GPU600, DDR720 + Mele F10
        MK902 Quickshot V3.1 1080p @1,8 GHz, GPU 600, DDR720 + Mele F10
        GT-I9505 OMEGA ROM
          Re: [CUSTOM ROM] QuickShoT v3.1 for cr11s with ap6210 and 5Mpx camera
          thanks to you for helping
            TWRP installed by default with reboot
            Hi, I saw in the descripition that TWRP is installed by default with this rom when you reboot.
            I have read some in Abdul_pt´s thread and I am a little bit uncertain how this actually works?
            I have a couple of questions for you guys out there that know this stuff:
            1. Where does the TWRP installs, i can´t figure it out because you can restore and backup ROM:s without erasing the TWRP or how does it work?
            2. Can you reset the box to Custom ROM and get the TWRP deleted incase of warranty repair?
            3. How do you boot a CR11S in recovery mode, I only know Bootloader/Flash mode?
            4. Does it have the latest version with Mouse support ?
            5. Is it possible to do a backup with TWRP on a fresh arrived CR11S box with stockrom and then have that copy to restore if you need to repair the box with warranty, and delete TWRP from that box.
            6. How do you delete TWRP if you don´t want it anymore?
            7. In abdul_pt:s thread there is a lot of talk about images files that is very connected to the device that you have, and there is no image file for CR11S? Should you use a generic one, and which one if you should?
            Hope you can bring me some light in these issues :-).
            CR11S AP6210 Chipset
            CS968 MTK Chipset MT5981 - MT6622
            HTC-T018-V04
              Hi! I will try to answer to all of your questions and give you some clear vision of what goes here.
              1.- The memory is divided into some partitions such as "recovery" , "system", "boot"..etc, twrp is installed on the recovery partition so it's not on the "system" area neither on the "internal sdcard" area.
              2.- Yes, just flash the latest official rom from a pc and you will reset the state to a "factory" state. Just like if it was brand new and never used.
              3.- on quickshot 3.1 we include a reboot app, open it and you will have different reboot options, one of them is "reboot recovery", just use that. Also, you can open terminal emulator and run this two lines followed by the "enter" key:
              "su"
              "reboot recovery"
              4.- Yes, and mouse is mandatory for using it properly.
              5.- That doesn't make sense since you can flash the latest rom and you will have a brand new state, so it's not necessary to make any backups. And think about this, if the box has some certain hardware problem it's probably that you can't either flash latest official rom, neither recover a backup.
              6.- Easy way? Just flash official rom.
              7.- Quickshot 3.1 comes with the correct twrp preinstalled so you don't need to choose anything. If the question is about installing twrp on a official rom, then this is not the correct place to ask.
              I hope i bring you light on this
                Super answer, that was the answers that I needed, thank you very much !
                "su"
                "reboot recovery"
                HTC-T018-V04
                  Hi you all, I managed to make the backup with TWRP and the ROM is awsome :-)
                  I have one issue though, I have KitKat launcher installed from Google Play and when I put a Widget on the home screen it dissapears everytime I do a reboot?
                  Is it a feature or a bug :-)
                  Pejochto via Tapatalk
                  CS968 MTK Chipset
                  MT5981 - MT6622
                  HTC-T018-V04
                  HTC-T018-V04
                    CS968 MTK Chipset
                    MT5981 - MT6622
                    HTC-T018-V04
                    Try Nova Launcher, it works ok
                      I have now the Nova launcher and it seems to work ok. The applications button ( dotted square) on home screen is not centralized, it occurs more to the right on the screen, is that the launcher default or a bug?
                      Also if someone knows, should you replace the default launcher with Nova in system, will it slow down to have two launhers?
                      Thanks for your answers and I think this ROM takes the box to a new level :-)
                      CS968 MTK Chipset
                      MT5981 - MT6622
                      HTC-T018-V04
                      HTC-T018-V04
                        CS968 MTK Chipset
                        MT5981 - MT6622
                        HTC-T018-V04
                        yes, that's a bug that usually occurs with small icons and 1080p.
                        No problem for having two or twenty launchers installed because you only use one at a time
                          I haven´t done any patching to this ROM, is the default 1080p with small icons?
                          Can it be solved if I patch the system with the big icon patch ?
                          Nice to hear that you can have several launchers installed without affecting the performance.
                          HTC-T018-V04
                            Overclock could damage....
                            I havethis cr11s box and
                            I have the 3.1 installed without any kernelpatch installed. Would you consider this Overclocked, because it says in the technical description that Cpu is up to 1.8 Ghz, and when I look on the Cpu with your Rom and its between 500 - 1660 something, isnt that in the security zone for my Cpu?
                            HTC-T018-V04
                              1800 is the maximum speed, by default they are clocked at 1600 max, lately units at 1400
                              Usually 1600 is a safe speed and 1800 is not reachable for some chips, my 3 rk devices got 1800, but 2 of them are not 100% stable at this speed (tested with a lot of benchmark's loops, for normal use it must work fine).
                              sent by my phone.
                              enviado desde mi teléfono.
                              leolas
                              My devices:
                              Gearbest.com)
