[CUSTOM ROM] QuickShoT v3.1 for cr11s with ap6210 and 5Mpx camera
that's good news!There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Re: [CUSTOM ROM] QuickShoT v3.1 for cr11s with ap6210 and 5Mpx camera
Originally posted by el_easy View Post@leolas ¿Is there any benefit use your Skin on XBMC and also ¿Can i change the default player on XBMC, for examples pressing any button on the remote control? ThanksREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by pejochto View PostNew report if anyone cares :-)
I flashed stockrom and then did power off/on test, no problem.
I flashed quickshot 1600 kernel on stockrom and the box didnt get as warm as it did with quickshot rom (strange)
But the power on/off test did fail on first try, i then tried several times, same result. No power on, stuck with red light.
Then reflash stock kernel and everything back to normal.
Conclusion, it seems that its not the overheating as I thought in the beginning, but why does your rom get the box real hot and not stockrom?
And what makes your kernel make my box stuck in redlight on start?
It must be some hardware difference if I am the only one having this problem, and with stockrom everything is working.
Originally posted by dony71 View PostHi Leolas,
Do you have TWRP recovery image for this quickshot 3.1 ROM?
I flash the ROM but strangely not seeing TWRP when I enter recovery mode from reboot appREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by dony71 View PostI couldn't see TWRP after install
That's why I ask you for recovery.img to reflashREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Please...
Hello leolas.
You know the details of a firmware, maybe can help me.
I have a CS968 V1 connected to a TV LG 42 '(42LG80FD). However, only works fully with the firmware: CR11S_cloudnetgo_ap6210_1080p_20131019_update.
Any firmware different than quoted, the image flashes.
Question: Exist configuration file that i can change to make fully compatible TV, such as occurs with firmware?: CR11S_cloudnetgo_ap6210_1080p_20131019_update
All firmwares, except the aforementioned, have the same problem when connected to my TV LG 42' (42LG80FD).
When connected to my Monitor/TV LG M237WA (23 '), works normally.
Grateful for his usual attention.Last edited by webipsum; 07 October 2014, 23:33.
Grateful for his usual attention.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Tks leolas!
Originally posted by leolas View PostAs far I know about the flickering problem (I can't reproduce this issue in any of my devices), it is a 3 factor's combination, it depends the concretedevice, HDMI cable and TV, the easy thing to be changed is the HDMI cable, the adjustment in the kernel only can attenuate the problem.
I exchanged several HDMI cables and the problem continues.
The problem must be incompatibility of the TV with the new firmware.
Like I said, with firmware: 'CR11S_cloudnetgo_ap6210_1080p_20131019_update', everything works fine.
With the most current firmware, images return the flicker.
Example: When in 'home - Android', the picture is perfect, but when I use the browser or Google Play Store, the problem of flicker appears.
Hugs.
Note: With the firmware 'CR11S_cloudnetgo_ap6210_1080p_20131019_update', the CS968 already starts at 1080p. With other firmware, the CS968, seems to start in 720p, although configured to 1920x1080-60.
dark image webcam
Hello everyone
I have a problem .... some time ago i open my CR11S and broke my integrated webcam (5Mpx) ....
so i buy a logitech webcam logitech c510, it's recognized OK, but the image is too dark .... i try with a microsoft hd-3000 too and the picture is too dark like the logitech .....
this is kernel issue, rom or both ??
is there any solution ???
regardsMK808B K.I.A.
MK908 Finless ROM 1.7a + Mele F10
CR11S Quickshot V3.1, 720p kernel @1,7GHz, GPU600, DDR720 + Mele F10
MK902 Quickshot V3.1 1080p @1,8 GHz, GPU 600, DDR720 + Mele F10
GT-I9505 OMEGA ROM
Originally posted by leolas View PostI will try but is really strange, any of the devices I have refuses to work at cpu1600; when I have some free time I will try to compile a kernel for you, what speed do you want? cpu1400; ddr ang gpu at?
.leolas
Leolas,
Any chance you compile kernel CPU1400 1080p with various GPU and DDR frequency?
Somehow my CR11 cannot take CPU1600, it will do reboot loop.
If you don't have so much time, please compile kernel with GPU600/DDR600 and GPU600/DDR720
There are currently 2540 users online. 2 members and 2538 guests.
