[CUSTOM ROM]QuickShoT v3.1 for cs968(ap6210 and 2Mpx camera)/CR11S(ap6210 and 2Mpx camera)
Re: [CUSTOM ROM]QuickShoT v3.1 for cs968(ap6210 and 2Mpx camera)/CR11S(ap6210 and 2Mpx camera)
Originally posted by ttherapo View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
boot loop
I upgraded a device CS918B (SZY_X6 V1_0 131024 AP6210) and got boot loop.
Symptoms:
1. the power button is always Red. It does not go Blue like normal ON status.
2. I am able to start the device only when the recovery button is pressed with the power ON/OFF button simultaneously.
3. I see the unit starts at 1080p, the funny splash is shown, then rotating 3D letters for a while; After that I get Android is upgrading /optimizing apps 1 of 8/, after this is finished and starting Apps appears, the device reboots and the same steps repeats for 2-3 times and then finally I got black screen forever?
Please advice how to fix the device.
dark image webcam
Hello everyone
I have a problem .... some time ago i open my CR11S and broke my integrated webcam (5Mpx) ....
so i buy a logitech webcam logitech c510, it's recognized OK, but the image is too dark .... i try with a microsoft hd-3000 too and the picture is too dark like the logitech .....
this is kernel issue, rom or both ??
is there any solution ???
regardsMK808B K.I.A.
MK908 Finless ROM 1.7a + Mele F10
CR11S Quickshot V3.1, 720p kernel @1,7GHz, GPU600, DDR720 + Mele F10
MK902 Quickshot V3.1 1080p @1,8 GHz, GPU 600, DDR720 + Mele F10
GT-I9505 OMEGA ROM
Originally posted by k3k View PostHello,
anyone got the AV-Out working?
I checked it with the composite cable but my TV doesn't get any signal.
Ideas?
Just pull 0.50 cm , disconect the hdmi and restart the tvbox becouse selecting AV from the menu while u are using hdmi out dont switch the signal to AV.
Wow, that's quite cool work mate. I'll check it out later.
Thank's very much!
EDIT:
Seems you showed me the right way to connect the three cables.
Unfortunately I just get a very flickering picture and some noisy sounds. The flickering and sounds vary if I pull oder push the cable a little bit in or out of the box.
Maybe I need to find the very right position, but until now I didn't.
Maybe any further suggestions?Last edited by k3k; 15 January 2015, 16:44.
Maybe try to change the video output between PAL/NTSC.
Now that i can remember in my older tv with no HDMI i could only get a flickering black and white picture with this tv box but once i found the "sweetspot XD" it stopped flickering but still b/w, in a modern tv it was in color and no flickering...
I dont think there is much to do other than trying another tv or cable
There are currently 1641 users online. 3 members and 1638 guests.
