UPDATED - NEW - TEST ROM and kinda cool!
Originally posted by clarkss12 View PostYes, I verified on Netflix website. Also, the kernel would not install, said "no command".
ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
how about the M8 Square box is there any chance to try this on M8?
I've tried Mini Launcher Working perfectly, XBMC gave me a "Minix only Error" ,Build.Prop Editing Solved that but xbmc application not starts after the first startup Loading ends ...
P.s I also Copied Minix_xml folder to system ...
Sometimes the update APP drops into recovery and says no command. Not sure why it does that sometimes. When it does just use the recovery menus to install the zip.
Originally posted by TMx View Posthow about the M8 Square box is there any chance to try this on M8?
Originally posted by clarkss12 View PostNetflix plays about a minute, then freezes. My other boxes hooked up the same way does not have this problem. Monday, I will start swapping cables. So far, I haven't seen much difference between this ROM and your 1.6 ROM. I will keep testing
Originally posted by Finless View PostYou have to install the kernel by hand from recovery by selecting install from EXT.
BobMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
OK. All is working .. ROM + Kernel (with recovery ext)
Test now, and report later.
Update:
Globally same as Tronsmart ROM. No nfs/cifs support. Same strange kernel (24Hz-1.99Mhz - Hotplug - can't manual modify) without Antutu cheat (lol).
Differences:
- Status bar no always visible
- Mouse cursor (Minix default one)
- Volume buton +/- in navigation bar
- Stop/reboot button (and app) in navigation bar
- Xbmc minix edition (not really test it... seems like Xbmc from Oman)
- Differents screens for screensaver...
- Antutu 22K (full screen landscape forced)
Nothing to see... Minix first rom is just the same than Beelink one.
Back to Finless 1.6 nowLast edited by roolmapool; 01 June 2014, 13:12.
Originally posted by roolmapool View PostYes, i do it with mele f10... it's really difficult (impossible?) with a mouse to use recovery.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 6301 users online. 2 members and 6299 guests.
