how do i restore a xbmc backup?
When you uninstall or reinstall xbmc it wipes :
on your SD Internal Card - /data/org.xbmc.xbmc
this is a hidden version , you can use ES File Manager with view hidden files in the settings.
/data/org.xbmc.xbmc/files/.xbmc/userdata/ is the folder you need to backup on the working version xbmc before uninstalling or reinstalling the xbmc version , just delete or rename the new userdata folder and copy you saved version to the same.
You may need to reinstall add-ons (videos, skins , etc) after you restore userdata because different versions of xbmc require different versions of add-ons
more here :
Titanium backups also allows backup/restore of data for selected apps.
There are currently 5544 users online. 1 members and 5543 guests.
