Different firmware, different behavior
sorry for over posting but keep on thinking of things to say and my smart phone hd crashed so I'm using an old palm pre which won't let me edit my posts. Basically it seems like if your cores never go back to higher frequencies or never go back online then its a probably an undervolting issue (to try and fix the heat issue) if they eventually do go back up its a cpu scailing issue which will help with heat but is less drastic because eventually all 4 cores will go back to online then go off once the threthold is met) I imagine this is why many box manfacturers aren't mass producing rk3288 in boxes and taking their time on minix (using s802-h) because manufactures can't properly cool them for the uses (intense hw and sw decoding) while compensating the heat issue.@µ$ł!Ω
I've reflashed everything AGAIN lol. Definitely getting much higher temps with Finless than i do with stock. Again, Finless idle temp is 70-80degC stock idle temp is 40-50degC. I can't understand why this is only happening to me and a few other people. Its strange.
Sent from my Nexus 5 using Tapatalk
Originally posted by Batfink32 View PostJust went back and tested stock 105k4.
The temps are at least 20C cooler than Finless 1.7. With stock my box never goes past 69C but with Finless the temps sit idle at 80C and throttle all the time. With stock temps sit idle at around 40C and never throttle. Finless 1.7 is unusable on my S89 because of this. This is the same behaviour I noticed from Finless 1.6.
Don't ask me, why Bob will not release a 192MHz fix, I ask him and told him the result, but no reaction...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Nowandlayda View Posthmm... Never really thought to look at this thread (title is not very descriptive about its actual content). This is very interesting though. However, I do not believe they are faking temperatures. ...RK3288 Devices
Re: Different firmware, different behavior
Originally posted by no_spam_for_me View PostBUT, as I wrote only because of the 'highly potent' CPU fix... Without CPU fix I get 40°C - 50°C at idle... with 192MHz (own mod based on Finless CPU fix) everything is fine, but at 1.7 I don't get 1.992GHz (only 1.6GHz) at 'cold state' automatically (I will have a look at it) only if I manually...
Originally posted by Batfink32 View PostOK, I've worked out what was wrong. I was using the CPU fix from the 101k4 ROM. This makes the temps cooler. The CPU fix from the 104k5 ROM has the same temps on Finless and Stock.
Sent from my Nexus 5 using TapatalkRK3288 Devices
FWIW, running Finless 1.7 (no CPU tweaks) I seem to be basically stuck at 75C. It doesn't seem fake to me, it runs noticeably hotter to the touch than it did with Finless 1.6.
I'm a bit nervous about it, since it's going to get a bit hotter still this summer, and I haven't been able to find a spec for max temp of the S802, but I would guess that it's somewhere in the 80s.
While I'm here, what is the best App for examining the behaviour of the cores and temps over time? I'm using "CPU Temperature" from the app store, but I find the CPU Cores + Freq readout confusing, and it doesn't seem to match what I can see in Antutu. Really looking for a good app that will track both in a reliable and accessible way.
Originally posted by Nowandlayda View PostI really don't think the temps are being faked. We need lokie and oman in this convo.
You can see in 105k4 dtd file:
Code:thermal{ compatible = "amlogic-thermal"; #thermal-cells=<7>; dev_name = "aml_thermal"; trip_point=<60 1608001 1608001 511 511 2 3 70 1200001 1200001 435 435 2 3 80 800001 800001 328 328 1 1 110 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff>; cpu_cali_a=<0>; idle_interval=<1000>; use_virtual_thermal; freq_sample_period=<30>; report_time=<1 10 30 60>; /* based on freq_sample_period */ cpu_virtual=< 500000 40 40 40 40 600000 45 55 60 65 800000 50 60 65 70 1000000 55 65 70 75 1200000 60 70 75 80 1400000 65 75 80 85 >; gpu_virtual=< 183 40 40 40 40 251 40 45 50 55 319 50 60 65 70 426 55 65 70 75 511 60 70 75 80 >; };
Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Hi, Omen
Thanks for your input
Questions: (to omen)
Can this unit ever run 2ghz (long periods) without a coolmod? (In your opinion)
If i do a coolmod..
Could/would the unit run at fullspeed?
Or would i need to custom/tweaked kernel for this?
I have seen people doing coolmods.. but the still have hight temps and throttles
Are you shure the temps sensor/software is accured?
If i do a coolmod..
How did you completely brick it? If it's not hardware you should be able to unbrick it.
There are currently 1566 users online. 0 members and 1566 guests.
