[CS968][MTK][4.4.2]Rootd
    just slight mod based on htc_t018_public_MTK_CSQ_4.4.2_20140504
    Changes
    • rooted with SuperSU (thanks Chainfire)
    • init.d support
    • TWRP 2.7.0.0 as recovery (thanks Abdul_pt). boot-up with reset button pressed to boot directly into TWRP
    • removed some apps, including BeyondXBMC and some google apps
    • YouTube for google tv 1.7.5 (you can still install standard youtube app from the playstore)
    Instruction (do this on your own risk)
    • flash stock kitkat firmware img (if you haven't already). And make sure it can boot properly.
      Originally posted by pincer View Post
      New firmware 20140504 here or here (htc_t018_public_4.4.2_mtk_20140504)
    • Flash this ROM using RKBatchtool. Choose UPGRADE, not restore.
    Download
    or
    Download GApps, Roms, Kernels, Themes, Firmware, and more. Free file hosting for all Android developers.
    Note
    may directly goes to TWRP on first boot, just select reboot to system
    (factory reset is always recomended)
    Credits
    • @900Supersport for the excellent kitchen
    • @pincer for stock firmware links
    • @Finless
    AP6210 applicable?
    can it apply to AP6210 version?
      Re: [CS968][MTK][4.4.2]Stock Rooted
      No. You will loose Wifi and Bluetooth.
      I can probably create a patch for AP6210 version. I'll take a look.
        Nice work...,
        If the patch is working, maybe you can try to patch leoas Quickshoot?
          if someone with AP6210 willing to test, here's the patch to fix WIFI and bluetooth
          AP6210 ONLY
          flash the ROM
          copy the patch to internal/external storage, and flash with TWRP
          note: files taken from cr11 firmware, so you might see cloudnetgo logo on boot. (i'm lazy)
            1080p version
            Thanks.. Any possibility of a 1080p version?
              Re: [CS968][MTK][4.4.2]Rootd
              Haven't seen kernel source for MTK CS968..
              I don't know yet.
              EDIT:
              Apparently we do have source code available. I'll start learning on kernels.
              No promises, tho 😁
              Sent from my LG-D802 using Tapatalk
                Changes
                • init.d support
                • Flash as usual using RKBatchtool
                Download
                or
                Note
                Credits
                • 900Supersport for the excellent kitchen
                • Finless
                HI, I'm a noob here, I stuck at "Smart Box" Logo, any idea why?
                Thanks mate!
                  Thanks mate!
                  How did you flash it?
                  Can you boot directly into recovery (TWRP)?
                    I flashed it with RKBatchtool => restored, just like any other flash method.
                    I tried the "Normal" htc_t018_public_MTK_CSQ_4.4.2_20140504 on my MK809iii, strangely it boot up and work just fine. But yeah it not rooted yet. That's why I'm trying to flash it with your version.
                    How can I boot directly into recovery (TWRP)?
                      Try powering up the stick while keeping the reset button pressed..
                        I did exacly as you said i manage to boot directly into recovery (TWRP).
                        And from there I choose reboot => system, but then still, I'm stuck at "Smart Box" logo.
                        Any idea what should I try next?
                          for the first run, IMHO, it took a while for it to properly boot. just wait it, i ussually get less than 5 minute, but sometime more.
                            I've waited for 20-30 minutes, but still stuck there.
                              Does the logo looks static, or animated?
