[CS968][MTK][4.4.2]Rootd
Re: [CS968][MTK][4.4.2]Rootd
Originally posted by btet View Postits animated, with glowing/shaining "Smart Box" text.
Try doing a factory reset in TWRP (Wipe - factory reset) and see if that helps.
I wonder if anyone else have this problem...
Sent from my LG-D802 using Tapatalk
- flash stock kitkat firmware img (if you haven't already). And make sure it can boot properly.
- flash this ROM using RKBatchTool, but choose UPGRADE instead of restore.
Do you have any tips & trick for my, so that the system on mk809iii not so easy to crash?
Originally posted by Wildwind View PostI had the same issue with my CS968. I waited for about 30mins and then decided to go back to 4.2.2 ROM which does not have this boot up hang at logo problem.
My repacked IMG seems to have problem with partitions IF you choose RESTORE in rkbatchtool.
Originally posted by Wildwind View PostI only did UPGRADE, still same problem
I am still trying to figure that out.
no bluetooth driver
Originally posted by farhanito View Postif someone with AP6210 willing to test, here's the patch to fix WIFI and bluetooth
AP6210 ONLY
flash the ROM
copy the patch to internal/external storage, and flash with TWRP
note: files taken from cr11 firmware, so you might see cloudnetgo logo on boot. (i'm lazy)
I tested this patch. Everything works great except it doesn't seem to contain the bluetooth driver?
I used the MTK rom with the AP6210 patch. I will try AP6210 rom now with the patch and report back in a bit.
UPDATE: The AP6210 ROM did not make any difference. There is definitely something wrong with the bluetooth. It will not turn on in the android settings, although WiFi is working perfectly.
Thanks for your work! Adding root and TWRP was a great idea.Last edited by greenepc; 17 June 2014, 19:38.
Originally posted by farhanito View PostGuess stock recovery is still needed to initialize certain partitions... So you need to be on 4.4.2 before using this.
Originally posted by greenepc View PostI tested this patch. Everything works great except it doesn't seem to contain the bluetooth driver?
i dont have AP6210 device, so i didnt test it myself.
Originally posted by Wildwind View PostWhat are the differences between FLASH and RECOVERY option?
I have question for you farhanito, I am about to build my own rom that can be flashed with RKbatchTool 1.7 as you have done with this ROM.But I Cant figure out how to make the rom prerooted as you have done. Are you willing to share that knowledge with me? I would be so thankful against you. I need this for my work and this is the only thing I have been struggled about for a while now If you want you can send me a PM with the explanation/solution if you dont want to share it here public. You think you can do that?
I know how to kitchen a rom so that would not be a problem.
sorry i dont understand the questionCR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
Originally posted by pejochto View PostI have question for you farhanito, I am about to build my own rom that can be flashed with RKbatchTool 1.7 as you have done with this ROM.But I Cant figure out how to make the rom prerooted as you have done. Are you willing to share that knowledge with me? I would be so thankful against you. I need this for my work and this is the only thing I have been struggled about for a while now If you want you can send me a PM with the explanation/solution if you dont want to share it here public. You think you can do that?
hope it will help. fell free if you have any further question
Originally posted by Wildwind View PostWhen using RKBatchTool. what is the difference between a flash and a recovery option?
seems like when you choose Restore the device will be wiped/formatted,
while Upgrade isn't, it will preserve your data. cmiiw
There are currently 3599 users online. 1 members and 3598 guests.
