I could criticize a BMW whenever I want to, I could easily list out 10 problems of it but I choose appreciate it because I know the efforts they spent to make it a good car. It's all about personality.
[Product Review] Minix NEO X8-H Quad Core TV BOX Review – Android 4.4 Kitkat + Amlogic S802-H Up to 2.0Ghz+2G RAM + 16G EMMC
Originally posted by Finless View PostOK you guys, STOP THE SHIT!
One of the rules here is NO NAME CALLING and insulting others! I run a friendly place and intend to keep it that way. All this crap does is pollute posts with useless banter. I don't care who you are either. My rules apply to everyone.
I don't give a shit who started it but I am finishing it.
Keep it up and you will get a time out!
If you want to debate, do it nicely and stick to facts.
Off topic
Originally posted by qwerty1221 View Postdamn MINIX you are not doing a good job promoting your company!
On topic.. (There some typ0's in the specs)
The box design does zero for me.. Nor the remote
Like
Ext antenna
Headphone plug
Easy to find reset
Imei code
Thoughts,
ARM CPU’s exceptional built-in thermal control management system protecting against any heat issues, giving customers peace of mind they can leave their device on 24/7/365
-the box does not seem to have any air vents..how did the solve the heat problem
Antutu reports no root.. I thought xbmc v13 needs root to work/play flawless?
-where can men d/l a copy of MINIX xbmc?
Skype pic looks weird..ghosting
Can the headphone out handle (high ohm) pro/dj headgear?
-how is the sound?
Can the unit do Bluetooth audio to BT speakers/headphone?
-what range
Any build-in support for gamepads ( USB or BT )?
Does it play ISO/3D?
Can I access ext2/3/4 partition/media?
Can the unit be fw-upgraded using SD?
Anyway.. It looks like a nice AIO android-box
Ps
Where did all the space go? 16gb of space/ 4.8gb free?
Originally posted by mitchell4you View PostAntutu reports no root.. I thought xbmc v13 needs root to work/play flawless?
-what range
Ps
BT range is going to be around 30 foot... industry standard on that but I usually find effective range ( as usual ) is less on any BT device
Space... if you are going by the example video... Some of it is used by the apps they installed to show off the device... some for the video's they showed etc. IN short... don't go by the video... lol
Originally posted by mitchell4you View Postthe box does not seem to have any air vents..how did the solve the heat problemRK3288 Devices
- Overview BOX (LINK !)
We solved the heat issue with a XXL heatsink + a big piece of metal which carries away heat by conduction, we guarantee there will be no overheating problem, our prototype machines are burning in at 100% loading @ 40C for 3 weeks and still running;
Gamepad drivers are there;
It does play ISO;
I don't know the partition thing;
By OTA, or Windows tool (which is easier to use than the RK's);
XBMC is 13.1 MINIX edition, support real 4K and doesn't require ROOT. (Can T4 does that?)
Skype sucks, Microsoft limited it, try Lync, it's also by Microsoft and works 10 times better, on the same box (but it's not free, hahaha);
[Product Review] Minix NEO X8-H Quad Core TV BOX Review – Android 4.4 Kitkat ...
Originally posted by gjs999 View PostHas a heatsink been fitted - MINIX any chance of some internal pics - save someone ripping their unit apart - please
Originally posted by gjs999 View PostThanks for the fast response - just have to wait for mine to be delivered - pity about Skype being limited as I was hoping to use this unit for that :-(
Originally posted by MINIX View Postyes, it has a XXL heatsink. (This is a picture from the sample, we use Samsung eMMC during mass production)
[ATTACH=CONFIG]6567[/ATTACH]
DEBUG1 DEBUG2 = UART ?RK3288 Devices
Minix.. thanks for anwsering some of the questions and the PCB pic
About my comments..
The space 16 gb /free 4.8gb.. picture inside the review
-under need it says:Total is 16GB, and system,and preinstalled apps take some storage, so everything is fine.
-best to state how much free space you get.. when you get your unit delivered
Please change the skype pic.. with someone behind the webcam
Could you..
Post a compatible game-pad list.. So, users can order them with there unit
Ps.. keepup the goodwork.. erik..and thanks for making the time to post a review
Looking forward on the game-play follow-up
There are currently 2572 users online. 0 members and 2572 guests.
