xbmc on your s89-h
Originally posted by picaye View Posttook me a bit to find this - tried the default xbmc first and then discovered this. works perfect on my s89-h and makes the box really useful (hardware video decoding)
http://www.freaktab.com/showthread.p...-s802-platform
just bookmark this http://blog.geekbuying.com/index.php...mart-vega-s89/
you will get all latest changes on there first.
does someone know if the minix version works as well? http://www.minix.com.hk/Support/14060516072927.html
they did a version for their new x8-h which should be pretty much the same than s89-h?
You always can try to use the latest nightly version of XBMC, use XBMC Updater to install it: https://play.google.com/store/apps/d...an.xbmcupdater
Sent from my Nexus 10 using Tapatalk
Originally posted by Nowandlayda View Postno xbmc updater will only update to latest stable and nightly versions of gotham (13.x) use xbmc helix alpha (14.x) for proper amlogic s802 and 4k support. No I do not believe xbmc for minix devices will work.
Important: Helix builds always have *master* in the filename
Which flaws does gotham have in relation to amlogic decoding?
Originally posted by gstar2 View PostWhat do you mean by proper amlogic support in Helix?
So either there is no proper amcodec support in gotham/helix for S802 (seems like an attempted backport from the MX platform) or there is a problem with the kernel display in finless 1.7 or both!
There are currently 3392 users online. 2 members and 3390 guests.
