Now NEO X8-H just support android smartphone/tablet control, NO APPLE, WP phone support. You also make sure your NEO X8-H and android smartphone/tablet in the same wireless network!!
Step 1: Open the remote control function in your NEO X8-H TV BOX:
Step 2: Download and install the following remote control app to your android smartphone or tablet:
Step 3: Find the app you just installed, should called: REMOTE IME, and then launch it, you will see this:
Just type the ip address above( it is the neo x8-h ip) and it will connect. then you will find this:
Mouse mode:
Ok, that’s all.
Enjoy your NEO X8-H!!
Eric
Geekbuying
Source from: http://bit.ly/TfSd2a
