How to control your NEO X8-H with your Android Smartphone?
Originally posted by mito View PostRK3288 Devices
- Overview BOX (LINK !)
Re: How to control your NEO X8-H with your Android Smartphone?
Originally posted by dems86 View PostFor XBMC use I recommend Yatse (it's in the Play Store). Hands down the best XBMC remote I have used on Android, it's just fantastic.
Originally posted by rick390 View PostI tried yatze but it requires my IP address and port number to connect. I put in my x8h IP address but I don't what my port number is. Is the port number on my MINIX x8h or is it on my router, can you advise?
and the settings info. Then just input it into yatse and it'll work whenever you fire up xbmc. But yatse should have an option in 'manage' within the settings to automatically find it. AFAIK
I don't have my box right now or else I'd show you a screenshot
sent from a SM-n900T // TWEAKD☆ROMâ„¢ // ODEXed for speeeed.
It is not working with X8H
I am using a new X8-H and the google TV remote is working, even Yatse for the XBMC. But I can not use the Remote IME. It cannot find the X8 IP Adress. Do I have to change something at the X8? Some access for the remote? I just need a possibility to change the size of maps in Google Earth or in sone games. Where can I find my firmware version?
There are currently 3280 users online. 0 members and 3280 guests.
