Vega S89 elite AV output Issue
Originally posted by summer View PostHas any one been able to get any video and audio to play from the external AV output jack. I have the 1.6 ROM loaded otherwise plays nice with the HDMI.
make sure you guys connect to the av port in TV, not the RGB port, i make a mistake when i first use the av , and in the end, i find i correct to the wrong port in TV. and change it, problem solved.
EricLooking for developers
Originally posted by geekbuying View Postmake sure you guys connect to the av port in TV, not the RGB port, i make a mistake when i first use the av , and in the end, i find i correct to the wrong port in TV. and change it, problem solved.
Eric
Where can I setup the a/v ?
At
[Settings] -> [Display]
I only find HDMI, and at
[Settings] -> [Other] -> [More Settings] -> [DEVICE / Display]
also nothing about a/v ???
BTW: only one at time possible? No HDMI and a/v?RK3288 Devices
- Overview BOX (LINK !)
Furthermore, uncheck automatic HDMI detection and set HDMI-576 or a lower mode. Make sure that you diconnect any HDMI cable from the box itself. I guess there is a small switch inside the HDMI connector that inhibits the AV output when a HDMI cable ic connected to it. Do a full reset and everything should work fine, the menu entries will be shown if AV out is active.
PS:
Ok only HDMI or a/v but not 'and'...
My TV shows that he recognise 'CVBS 576i' but only shows on screen like 480 so I lost a lot of... but if I switch at [Settings] -> [Display] to 480cvbs the screen nearly fits ...RK3288 Devices
Note,
You Might find another bug..
When using xbmc.. Playing a vid with a bigger resolution then screen
Then xbmc doesn't resize the vid to match the borders of your screen ( aka..most of the vid is off screen playing)
Or
If you set.. Letter size to big in android, apps will start playing 90degrees
Note: use the a/v cable that came with the unit, others don't seem to work
Anyway..
There are currently 2979 users online. 0 members and 2979 guests.
