Wolder MiTab Sunset. 9.7
Dragonpat, so is this ROM I have done ready for prime time? e.g. ready to come out of beta so I can post in in the ROM forum for others? Or does it need something?
Originally posted by Finless View PostDragonpat, so is this ROM I have done ready for prime time? e.g. ready to come out of beta so I can post in in the ROM forum for others? Or does it need something?
But I have modified it taking out more apps.
Thanks!
Enviado desde mi Galaxy Nexus usando Tapatalk 2
Originally posted by dragonpat View PostThe rom is ready for dairy use without problem. Is great and fast.
Thanks!
Thanks,
Originally posted by Finless View PostCould you list what you took out and I will make the final ROM without them.
Thanks,
Here you are.
Aix weather
Aldiko world
Angleclock
Appcenter
Appwolder
Bookstablet
Documents world
Facebook world
FB reader world
Fruit world
Genie widget
Maps
Rkebook reader
Street
Thinkfree
Twitter
Wisky_app_stopwatch
Wisky_app_usrmanul
Wolder
Youtube
Originally posted by dragonpat View Postbob is there any way to make a flaseable zip from recovery of the rom?
Remember though a ZIP does not really flash a ROM. It just writes all the files in the ZIP to the system or data paritions.
Originally Posted by dragonpat<br />
bob is there any way to make a flaseable zip from recovery of the rom?<br />
<br />
<br />
Yes of course! Use titanium backup to make a ZIP file. Then use CWM to install it.<br />
Remember though a ZIP does not really flash a ROM. It just writes all the files in the ZIP to the system or data paritions.<br />
<br />
CWM ZIPs do not "flash" a ROM. They simply install files into the partitions.
It's more compicated that that. A full ROM flash flashes the partameter file also which sets up the partition sizes. It also makes the paritions. It also flashes the kernel (RK29 CWM cant do that!!!!!).
So when you wipe it is like erasing a disk. Just erases data. It does not FORMAT the disk. Then it uses the ZIP to write all the files back in the erased disk. Like a "ghost" image. SO again... it is not a full ROM flash. It is only rewriting files in
Cache
Data
System
And it writes the new boot,img.
It does not wite kernel, recovery, or the pararmeter file.
Because the original is full. Remember it is a disk image. So to make more space you have to make a NEW disk image that is larger and copy everything from the old image into the new image.
Originally posted by Finless View PostBecause the original is full. Remember it is a disk image. So to make more space you have to make a NEW disk image that is larger and copy everything from the old image into the new image.
so if I create a new image then I must change something more in the rom? parameter or anything?
There are currently 2511 users online. 0 members and 2511 guests.
