ADB on EM8 square working
Originally posted by mag_freak View PostJust tested ADB on EM square box.
Seems to be working.
Need to open the box
Place jumper at ID_SW (between usb & HDMI)
Start box & enable USB debugging
Use male usb <=> male usb cable
Use left USB connection (on edge of the box)
Tested with ADB, seems to connect.
[ATTACH=CONFIG]6597[/ATTACH][ATTACH=CONFIG]6598[/ATTACH]
Originally posted by TMx View PostWell Done Mate Thats the best news we heard after a long time
JustMeBugs are Sons of Glitches!
JustMe
Hey thanks! I had not taken my M8 apart yet. This should really help a lot!
reason maybe 5 cent...RK3288 Devices
- Overview BOX (LINK !)
JustMe
Originally posted by zektor View PostFunny that all they did was remove the jumper before closing and shipping this. Does anything *not* work with the jumper on? In other words, any reason to remove the jumper after putting it on as far as you can tell? Nice find btw...
The left-usb port is a multifunctional port, function selectable by jumper.
Other boxes have seperate OTG port.
Foodog
Originally posted by mag_freak View PostWith the jumper on the left usb-port doesn't work with usb stick, mouse, etc., there is no 5V.
Yes and No
You need OTG (and not USB-Host) to connect the port with the USB-Host-Port at your PC to work with ADB (because Host to Host doesn't work)RK3288 Devices
On the newer ENY-M8S you will need to solder that 2 pin plug onto the board as they have removed totally.... I cant speak to the M8C but i just bought a whack of M8S's and everyone of them came without that jumper... Once i installed the jumper ADB on any of my linux or pc boxes instantly connected to the M8S...
There are currently 1462 users online. 0 members and 1462 guests.
