Power problem?
Originally posted by sdspieg View PostSo there is no power unit inside that can be replaced or anything?
You should never replace the power supply with a unit that provides more voltage than the device is meant to have... this has always been true with any electronics. Most only have a limited percentage of tolerance
absolutely right -->> always use a powerunit with EXACT the same settings as voltage ...... and so on
NEVER EVER use a powerunit with higher voltage or ampere oO
in my opinion your minix is now in heaven :C
iam sry 4 u
the moment when ur minix is burning by the other powerunit u wont recognize it (my english is terrible ^^)
u wont hear a "splaaaasssh" or "bang" -> no sound at all or clicking ;D
try to find a powerunit which has EXACT the same settings like the minixpowerunit and test if the minix will run again.
if not ->>>iam sry 4 u
Actually... you can use one that can provide higher amperage... a device will only pull as many amps as it requires and having a supply that can provide more won't hurt anything.... but when it comes to voltage that is another matter and it can/will damage components.
The basic rules for replacement power supplies...
amperage - requires the same or more amperage... less often means the device won't be able to work properly
voltage - always use the same voltage... not more or less
12V Power Supply...
I should have been more careful but i wasn't and I used a 12V power supply by accident and now my unit won't power up either...
Is there no overvoltage protection built into these devices?
I am assuming that it done but maybe someone has come across this and fixed it.
Any help would be appreciated.
There are currently 4284 users online. 1 members and 4283 guests.
