Bricked X7 when flashing from KitKat to official 008 ROM
I flashed KitKat ROM a moment ago, but when i tested xbmc i had same problems that with other ROMs. I tried to flash back to official minix firmware 008, which i was supposed to update to 010. Flashing failed. I have flashed to that ROM from other ROMs (not kitkat) before without problems. Now when I try to connect X7 to computer in recovery mode, it stays connected only a few seconds and then disconnects. I cant flash anything or otherwise connect to my X7. It doesnt even power on. Does somebody know what might be the problem or better yet the solution, or have I bricked my device forever?Tags: None
Originally posted by Ancca View PostI flashed KitKat ROM a moment ago, but when i tested xbmc i had same problems that with other ROMs. I tried to flash back to official minix firmware 008, which i was supposed to update to 010. Flashing failed. I have flashed to that ROM from other ROMs (not kitkat) before without problems. Now when I try to connect X7 to computer in recovery mode, it stays connected only a few seconds and then disconnects. I cant flash anything or otherwise connect to my X7. It doesnt even power on. Does somebody know what might be the problem or better yet the solution, or have I bricked my device forever?Please consider making a Donation to freakTab
http://minixforums.com/threads/bricked-minix-neo-x7.3865/
If you have have any questions wright back and we will solve your problem
Many thanks to both! I got it working again by following this link http://minixforums.com/threads/brick...x-neo-x7.3865/
it happened to me but i kept reading hope you get it sorted.
this is what i got just follow the threads it will be ok im sure.
i hope some1 can help me, i had qs3 on my x7 because we have altered the i have not been up to date so i have been looking and seen there was an up date,so i tried to update the x7 thru windows7 useing the lead that comes with it but now i connect to in x7 and it will only stay on less than 7 seconds ( i have been reading the threads and tried everything ) plus when i try to connect i get the mocksom i think it was. just need the right files to do it or is it bricked all together thanks.
this is what im getting
INFO: Start to erase NAND
INFO: Start to lower format
INFO: Doing lower format. Total (2048). Current (897).
ERROR: Lower format failed.
ERROR: Erasing IDB failed.
now i realize i have tried wrong rom been going thru post again installed the drivers, must it be a usb cable and not the 1 that comes with it tnaks.
Still in trouble?
Take a tool to flash a Kitkat rom (not the Qs3, as it doesn't have the option to format), I took the tool in Miracle rom 1.1 from Genny in Minix forums. See that you have the Loader marked 2. something as first line, than click on erase IDB. The count must arrive to 4096 if I am not wrong. Than you can change rom if you want and load another tool for the rom of your choice (or go on and flash Genny's rom, altogether). If you have problems ( after clicking the hidden pin together with power to put Minix in flash mode ) keep the power button pressed for the whole process ( during erase idb or later during flashing of the whole rom of your choice - btw once you have the new rom in the tool, you do NOT need to erase idb a second time before starting flash operation! )
Let us know
Alessandro
Inviato dal mio Nexus 5 utilizzando TapatalkLast edited by vn800art; 29 July 2014, 14:11.
I bricked my x7 a lot of times, most of them because I wanted to brick it to test a secure way to recover it. all of the times, with Windows XP, or Windows 7, pressing both, recovery and power the whole flash process, the device was unbricked. Without need to short Pines on nand.
I used rkbachtool 1.7.
sent by my phone.
enviado desde mi teléfono.
There are currently 1688 users online. 0 members and 1688 guests.
