Pipo M7T RileyROM 1.4 KitKat
    That's great news!!! The charging issue may be due to a change in battery stats. Hopefully it will work itself out with multiple charges.
    Randy
      Randy, thank you for your ROM.
      It is really the best one! But there is still one feature (common for all official and custom ROMs) that looks annoying. 3g quality is rather poor... It can be out of work in places where my mobile phone (jiayu g4t) with the same SIM card shows excellent signal... Is there any way to improve that?
        When installation is Xposed frameworks + GravityBOX and a few other modules ROM is perfect and fast. Unfortunately battery problem I still have (charged to 100%, maximum 94%).
          hello!
          Pipo M7T with rileyrom 1.3.
          Question: Can I somehow flash a new rileyrom (1.4.1) keeping installed programs and settings? One (1.3) flashed by default setting.
          thanks.
            I would advise against it. There are differences and parameters and file sizes with this ROM. You should always erase IDB and flash a new ROM each time.
            I have good luck with Titanium backup and "Restore Missing Apps and Data" after each flash.
            Randy
              ebook do not work in the rom 1.4
                My m7t is restart himself from time to time with rellyrom 1.4.1 ??????
                Is one saw this problem in his m7t!!!!!
                  Yes, I'm experiencing same thing from time to time. But I don't think it is a Randys fault. Original firmware is worth.
                    is it in the Official firmware too???
                      There its happen more often to me.
                        I will install the Official firmware and see
                          Just updated to 4.4.2 official ROM but seems to be unstable.
                          It reboots very often. Does anyone else has the same problem?
                          Is there any more stable ROM?
                          I just saw that ****.co.uk sells the M7T with pre-installed the 4.4.2.....
                          Did the pipo made any new stable rom?
                            It does reboot often - but the exact same thing is happening with official 4.4.2 Pipo rom.
                            So - I guess it's Pipo's fault, and we have to wait for any updates from their side, which won't presumably be happening anytime soon...
                            Or maybe the author of Riley Rom will be able to solve that problem in some other way?
                              I use PipoROM 1.4.1 +Xposed + GravityBox + some moduls and I'm satisfied. None restart. It is fast. Only occasional lag. It is a custom ROM so it needs to be well maintained. Most problems arise between me dispalyom and chairs. Riley Thank you and I look forward to the next version.
                                So, which ROM do you suggest for stable use?
                                Offiial 4.2.2 or Riley's 1.4.1?
