Finless ROM "tweaker" for the Neo X8 stock ROM BETA 002 6/16
I don't know why your browser is gone? I just tested and it is there for me. I have NO command in my script to remove it.
What ROM did you install my patch on?
If you look in /system/app/ the Browser.apk should be there.
UPDATED
OK tweaker patch has been updated to fix the root issue.
Link is in the first post.
New file name is now:
neox8_finlesstweaker_4_beta_rom002a.zip
Sorry for the mistake.
No worries
Originally posted by Finless View PostI don't know why your browser is gone? I just tested and it is there for me. I have NO command in my script to remove it.
I did a clean install of Hardware Guru's flashable Beta 2 - the full factory reset zip. Booted it once, set up screen, then flashed your tweak set and rooted the rom. Hey presto, brilliant Ethernet.
But no browser..no worries, I've found an apk.
Originally posted by zektor View PostGuys, the missing browser has nothing to do with Bob's tweaker. It is missing even BEFORE installing the tweaker. The funny thing is that it is in the rom, but it does not install. This is with flashing:
UPDATE 18-06-2014 (002Beta2) X8-H Flashable zip for NEO X8(H)
Your talking about Browser.apk or something else?
Icon shows up in the AOSP launcher as a round globe.
Yes Indeed
Originally posted by Zahir View PostYou're quite right. It's been there all long in system/app - but won't install.
Again I am not having this problem at all. It shows up in APPs with the AOSP launcher. I did not check using the MINIX launcher. Maybe that's where your not seeing it?
I'm no newbie at this stuff anymore,done it a hundred times now,but I can't get my X8-H to boot into recovery for love nor money - at least not with the SD card plugged in. Before you ask , no otg cable plugged in, no usb devices or Ethernet etc and SD is fat 32 - what's going on? Could it be that it's a 32gb card? Had no issues flashing zips and updates on the X7 or the Vega S89.... Any ideas? Suppose my option is find another SD card and eliminate that idea... Just thought I'd ask as its usually very straightforward and I am fully able to follow instructions lol
Sent from my HTC One_M8 using Tapatalk
Re: NEW - Finless ROM "tweaker" for the Neo X8 stock ROM BETA 002 6/16
Originally posted by Smokez View PostI'm no newbie at this stuff anymore,done it a hundred times now,but I can't get my X8-H to boot into recovery for love nor money - at least not with the SD card plugged in. Before you ask , no otg cable plugged in, no usb devices or Ethernet etc and SD is fat 32 - what's going on? Could it be that it's a 32gb card? Had no issues flashing zips and updates on the X7 or the Vega S89.... Any ideas? Suppose my option is find another SD card and eliminate that idea... Just thought I'd ask as its usually very straightforward and I am fully able to follow instructions lol
I don't see why the SD card should matter. recovery will be there no matter what.
also if you have root, you could try a reboot app that allows to reboot into recovery. I know finless Bob packs one into system/app on his Rom and tweaks. maybe pull it from there and put it into system/app and change permissions to 644 with a root explorer
Sent from my SM-N9005
I do not know what's going on with some of you and the browser
I just flashed the Minix ROM clean. It's there!
Then installed my tweaker, it's there!
WTF
Maybe you guys got some 002Beta earlier than I did and it has changed? I suggest maybe re-downloading it. I downloaded my copy 2 days ago not right away.
There are currently 2538 users online. 0 members and 2538 guests.
