Verstuurd vanaf mijn T5 met Tapatalk
ROM: HardwareGuru 5.0 Malipatch/HLS/DRM for X7, X7mini
kiiboard
Originally posted by natzen View PostThanks guru ,very good rom but i have problem with my hardware keyboard ...rii mini i8 (qwerty) not work properly ...he walks like azerty,i changed all parameters in language but not work .
Help me please
I am having same issues here. worked great on v4/. on v5 keys dont match. seems as if its in azerty or some other format/. my "a"is a "q" among other keys that do nt work help a brother out. thanks
Re: ROM: HardwareGuru 5.0 Malipatch/HLS/DRM for X7, X7mini
Originally posted by vn800art View PostCorrect!
Inviato dal mio Nexus 5 utilizzando Tapatalk
Originally posted by dynamic_d View PostI am having same issues here. worked great on v4/. on v5 keys dont match. seems as if its in azerty or some other format/. my "a"is a "q" among other keys that do nt work help a brother out. thanks
FANTASTIC HARD GURU !!!
Congratulations HardGuru. The rom was great. So far working 100%. Quick to open and close applications. He rolled all my files. 1080p MKV without gagging or crashes (I'm using XBMC player). In Antutu Benkmark = 19,070 points (Very Good). Wifi and Ethernet OK. Netflix, YouTube and Browser Native functioned smoothly . The initial boot was a wonder. Beyond a doubt, this is the best ROM I have experienced so far. If I observe any problem will relate to you. Hugs coming from Brazil!
Originally posted by HardwareGuru View Postok thanks.
uhhm my bad.. we sell rii azerty. so i think i put in the wrong keymap for rii.. i will update it tomorow.
btw while flashing your rom my x7 would softbrick so i had to hold the power button on it while it flashed the entire time this is the first and only rom to do that it took me 3 trys and going back to wasser's rom to realize it was just the rom file idk if anybody else has brought this to your attention
im new to this still
but i do know how to flish and install apks and use your root kit so far on the x7
So you're saying it won't fail to properly play an mkv like: http://thepirat****.se/torrent/94888..._5555_-_BR_Rip
Hey man thanks for the great rom.
the Dutch stuff works finally. It worked on other devices but not on my X7, now it does.
The only thing I found is netflix, the app works normal but when opening a stream the first 20 sec gives messed up image. After that the image restore and works well.
but I really don't like 4.2 anymore. 4.4 is much faster.
soo, I am looking for a way to learn how you fixed NPO on your rom.
3FM cam doesn't work on any rom, accept this one.
can you learn me how to make this work, or can you make a fix for this yourself?
i would like to use quickshot's rom v3.1 and keep this working.
already thanks a lot for your hard work, medenederlander ;-)
Yes the netflix thing is a known issue and I know guru is working at this.
Thx,
KAR
Hey KAR,
if this netflix is a known issue, then why this is not readable at first post on head 'known bugs' ?
because now it looks like there are no bugs. See the first post at:
Known bugs:
- none yet
Thx,
KAR
There are currently 2076 users online. 0 members and 2076 guests.
