PLEASE HELP! --- NEXTBOOK 7 run down please?
    OK guys, I think the nextbook 7 and all the models, serial numbers, etc is just out of control keeping track of what works on what and all the serial numbers / models
    So I ask that people try to help others and reporting what serial number you have and what ROMs work.
    I think we need a run down of this mess if you ask me?
    So please report what you have, model like S, P, etc... and what your serial number is and what ROM works for you.
    Next7P
    NextBook Premium 7
    Serial: YF121121263
    Manufactured: Dec 2011
    Android Version 2.3.1
    Build #: GINGERBREAD.P1211.FreakTab.Finless.V1.5_HW:2.0.0.0 .0
    Works Great all the time no complaints.
      Serial number
      Hey there my Serial number is YF031289089. All the other info is in the Build.prop file I uploaded to the other forum here (Android Talk?). Hope it helps.
        Next7P YF1211 only working with Finless' #1011
        Next7P YF1211 only working with Finless' #1011 on ROM 1.4 and 1.5.
        Latest BETA 2.1a (newer #1211) tried and failed on sound and wifi (and missing soft buttons).
        Rob / jrm
        _________________
        N7P rooted w/ Finless #1011V1.5 (was V1.4)
          So it appears we are not going to get much help from nextbook users here making a list of models that exist and what works on them. I am dissapointed people are not willing to help others by inputting
          I get a PM or there is a post daily asking what to use. I do not know and cannot help them.
          So you guys really need to try and help put a list together for other users!!!!
            Nextbook 7s
            Nextbook 7s Serial no. YF031270977 Ice Cream Sandwich 4.0 Finless rom 1.2 Works just fine...
              NextBook Premium 7 S/N 0911
              Model: Nextbook Premium 7
              Serial Range: YF0911
              Screen Type: Capacitive (For further clarification)
              Working Roms: Here's a link to all rom's I've discovered that works with this tablet.
              I looked at all of these posts in this thread and I thought lol (No offense implied). The only link I've seen was to a post that reported that it didn't work. (Which is probably a special case of wrong serial # or refurbished)
              So at the very least report the Model, Serial # Range, and a link to the thread of said working rom
              Well here's my speculation over all the confusion over all the Nextbook Premium 7 (Capacitive only).
              There's really only 2 main hardware version and they're listed below in groups.
              Version1: 0811,1011, and the occasional wrong serial# refurbished tablet
              Version2: 0911,1211,0512
              If there's a number range not mentioned I either don't know about it or can't be bothered to track down info about it lol.
              NextBook 7 Premium -S/N 0911 Running one of Many Finless Bob's Roms found here!
              Yuandao/Window N101T (Model 1:2nd Batch) Running Finless Bob's 1.6 Rom kernel# 26
              Found Here
              ZTE Score (X500) running a rooted stock rom.
                Tablet: Next7s (Resistive)
                Serial: YF031298231
                Rom: ICS 4.0 Finless 1.2
                By the way finless, I just bought this tablet on Friday, had it rooted and downloading from Playstore 10 minutes after purchase thanks to you.
                You ROCK Finless.
                Sent from my Next7S using Tapatalk 2
                  My advice is if you have a #1211 or #1011 Nextbook Premium 7, make sure you have a copy of the STOCK ROM for each model number saved to your PC. This is due to the inconsistency of Nextbook labeling and can help you out of a brick situation.
                  My tablet: Nextbook 7 Premium #1211 (Model: Next7P)
                  Capacitive Touch Screen
                  1GHz Cortex A8 Processor
                  OS 2.3
                  8GB SD Card (Max 32GB)
                  G-Sensor
                  I have NOT tried it but the Manual says the reset hole on the back doubles as a mic.
                  1. All Finless Bob's ROMs up to 1.5 work perfectly.
                  2. I have also successfully tested and proven that Bob's #1011 version of these same ROMs run perfectly on this device.
                  3. For a very short time I tested Bob's Newer 1211 Nextbook ROM used as a base for GingerComb.
                  (please note, I did not have the time to test this Rom properly)
                  The errors I did come across were:
                  a. Unable to connect to Wi-Fi even though I was able to recognize signals.
                  b. No sound
                  These appear to be minor and fixable things, when I have more time.
                  4. After that, and again for a very short time period, I tested Bob's Older 1211 Nextbook ROM used as a base for GingerComb.
                  a. The Wi-Fi fired right up. Sought out signals, and signed into my home network
                  b. I had no problem with sound working.
                  c. The battery icon did NOT appear. (Bob may have fixed this already)
                  d. Screen Orientation was off, however Bob showed me how to fix it with a simple build.prop edit.
                    Sorry Bob, haven't been in here much lately.....Messing with my Poloroid tab recently
                    Nextbook 7P S/N: YF121115640
                    Finless 1.4 Rom: No problems, Loved it!!!
                    Finless 1.5 Rom: No problems, Loved it even more that 1.4!!! (appinjector was a super plus!!!!!)
                    ICS 1.2: No problems, just ran a little sluggish; minor video problems (probably my fault) went back to Finless 1.5
                    Sorry I didn't get back to you sooner... Keep up the GREAT work
                      hey there, just wanting to report success with finless 1.2 on a nextbook 7P12 serial YF0312......
                      Followed all instructions in the readme and it worked just fine. Much thanks!
                        Finless--
                        Thanks for putting all this together. I am new to this site and you have some good information. Still swimming through it all.
                        I have the following.
                        Model: Nextbook Premium 7se
                        Model Number: NEXT7p12
                        Serial Range: YF0412
                        ROM:
                        nextbook7p12se_root_gplay
                          YF0511
                          Hi all,
                          I have 2 Next7P's, one still has the original stock firmware on it, the other was bootlooped, and just last night I tried the 0811 stock rom on it, It's working now. Now that I'm finding out what works, I can begin to play around a little bit more.
                          Thanks, Finless!
                            Originally posted by crackitopen View Post
                            Hi all,
                            Thanks, Finless!
                            Your welcome! Glad I could help
                              YF031280371
                              Next7S (resistive screen)
                              running Finless Bob's 1.2.
