I'm using the most recent version of the SPFlashtool, and it works pretty well.
One known issue with this tablet is that rooted backup apps, like Titanium don't work, because they can't write to either internal or external SD. I'm still searching for a solution to this. I've made the necessary edits to the platform.xml file for permissions...and you can copy files back and forth with a rooted file manager, but these rooted backup apps just won't do a backup. I so far haven't tried a CWM backup/restore yet.
I've flashed this a few times with good results. The flashing process doesn't erase apps or userdata, and results may vary depending on what you might have already installed on your tablet. At one point, I lost the soft buttons on the home screen, and the ability to use the keyboard. All I did was get into stock recovery and reset the device to factory settings. With a clean sleight, things worked much better. As I'm learning these MTK ROM's, I will try to figure out how to get the format/download feature working on the Flash Tool.
In the meantime, though...this tablet runs smoothly with this ROM. I haven't run an Antutu score yet, but it appears that the apps I've tried work pretty well.
Included in the ROM Kit is a First Time User's Guide with detailed instructions on the flashing procedure with screenshots of the SP Flash Tool.
This ROM is:
Rooted with SuperSU
Debloated of all Chinese apps
Google Play Store fixes added
Init.d support added
Busybox commands added
Your choice of stock recovery or CWM Recovery...just select the recovery file in the flash tool before flashing
Autoinstall added for apk files in your external SD "autoinstall" folder (not tested yet)
Reboot app by Petrus
CWM created with MTK Multi Tool
New boot animation and shut animation
USB drivers included in the ROM kit
Again, just read the First Time User's Guide for instructions.
Download
Enjoy!!!!!!!
Donations are appreciated. Just see the link in my signature line.
