Netflix problems?
Netflix problems?
Since it was updated to 3.6.0 the other day I noticed I cannot play back in anything but a "phone resolution", evn with the ID fix on Finless v1.0 spoofing it to a Nexus 10. I rolled back to 3.4.1 (thankfully I kept it) an it is playing HD again. But what can be the problem with the latest version? I can;t imagine they blocked HD playback for the Nexus 10??Tags: None
Originally posted by zektor View PostSince it was updated to 3.6.0 the other day I noticed I cannot play back in anything but a "phone resolution", evn with the ID fix on Finless v1.0 spoofing it to a Nexus 10. I rolled back to 3.4.1 (thankfully I kept it) an it is playing HD again. But what can be the problem with the latest version? I can;t imagine they blocked HD playback for the Nexus 10??
Can you please share the apk? I am having problems with netflix too. On my x7 it worked fine. It wasn't HD but i watched videos smoothly. I had netflix 3.3.0
With the x8 i get a glitch in the sound every couple of seconds. It is annoying.
Anyone experiencing the same issues?
Originally posted by NikAmi View PostI'm pretty sure that that has to do with the network performance problems people have been having on the stock ROM.
Sent from my HTC One using Tapatalk
Originally posted by zektor View PostSince it was updated to 3.6.0 the other day I noticed I cannot play back in anything but a "phone resolution", evn with the ID fix on Finless v1.0 spoofing it to a Nexus 10. I rolled back to 3.4.1 (thankfully I kept it) an it is playing HD again. But what can be the problem with the latest version? I can;t imagine they blocked HD playback for the Nexus 10??~Gopichand Pai
Originally posted by gopichandpai View PostYes, same issue here as well. I can also see some texts are chopped off too.
Another thing, can you check the OS API # in your Netflix app?
Originally posted by WeK05 View PostI checked a couple of movies and I don't seem to have that problem. Is there any particular video that I should try?
I am back on latest Netflix now. OS API# is: 15. What does this mean?~Gopichand Pai
Originally posted by gopichandpai View PostIt was an issue when I watched "Coupling". It is fine in other videos.
The OS API# tells you the system's API level. 15 is for Android 4.0.3 and 4.0.4. For Android 4.4 it should be 19. I am not sure whey it is being reported as 15 on X8. It is 19 on my Nexus 7 tablet.
http://developer.android.com/guide/topics/manifest/uses-sdk-element.html
There are currently 1850 users online. 0 members and 1850 guests.
