Please help,
MK808B + Finless 1.7 Problem
My MK808B started to give me a messages about apps stops working as soon as I turn it on, and when I click on any apps I get nothing, and even when I go to setting, then apps to uninstall them, the menu disappear as soon as I click on the uninstall option.
Please help,Tags: None
There is no official cwm rk3066 devices, that's why the play store app can't install it. Download the inofficial one from here: http://androtab.info/clockworkmod/rockchip/rk3066/
misc.img and recovery.img are images of the misc and recovery partiton. If you download cwm you find both in the zip file. You can flash them both using the flash tool you used to flash finless 1.7. Just uncheck everything except misc and recovey, choose your cwm files and flash it like you flashed finless 1.7. You can also rename the cwm zip file to update.zip, place it on your external sd card and reboot. After the next boot you will be promted if you want to install an update. The "update" is cwm.
There are currently 2909 users online. 1 members and 2908 guests.
