I am told this is an Android feature but that doesnt make sense to me.
So here is a fix. This is a new wpa_supplicant file that supports adhoc networks.
http://video.freaktab.com/?subpath=f...supplicant.zip
Instructions:
1) Download the wpa_supplicant.zip file and unzip the wpa_supplicant file to your sdcard.
2) You need a root file explorer. You can get ES FIle explorer free from Google Play.
Now ES file explorer does not browse or mount system as RW by defualt. SO once you first launch ES File explorer do the following:
Go to setting for ES file explorer.
Go into file settings and turn on Show hidden files then back up one level
Scroll down to Up to Root and turn that on
Scroll down to Root Explorer and turn that on
Turn on mount file system RW
3) OK so back out of setting and navigate to /system/bin
4) Rename wpa_supplicant to wpa_supplicantold
5) Navigate to your SDcard and copy the wpa_supplicant to /system/bin
6) Hold your finger on the wpa_supplicant file and in the pop up, scroll down to properties
7) In properties click the change button so we can change the permissions
8) Make sure all 9 boxes are checked for permissions and click OK.
9) Now just properly power off your N101 and power back up.
BING! You now have Adhoc wifi support!
