MK808B coming with REALTEK WiFi/BT solution (ORIGINAL)
Originally posted by geekbuying View Postbut you can write the request you need, i will talk with bob,and factory, and try to release a new custom rom.
Originally posted by danilocelic View PostHow did you accomplish the extraction of the boot and recover img files?
I used that tool to extract the boot and recovery IMG files from the stock ROM posted earlier in this thread. I flashed my device with Finless ROM 2.1 ( http://www.freaktab.com/showthread.p...inless-ROM-2-1 ) I used the 720p kernel and boot IMG as the stock ROM is 720p. I then immediately flashed the device only with the boot and recovery from the stock ROM.
I used this tool: RK3xxx_firmware_tools_4.2.80.00, to extract the image. Then I extracted the system image. Replaced the su file in system/xbin folder and recompiled the system image and also recompiled the whole firmware image. This roots the device. Also a program called vroot also works well.
In the process of uploading a patched stock firmware for this device which gives it full root access and also solves the stuttering issue. 1080P can be obtained using terminal emulator and using the following commands:
su
am display-size 1080x1920
am display-density 240
Also, make sure to change the lcd density in build.prop as well from 160 to 240. This will give you true 1080P resolution and you only have to do it once, stick will remember the settings. The latest SPMC version spmc-armeabi-v7a_13.2.0 gives best results in video playback of 1080P content, very smooth. You can also use your choice of xbmc nightly or beyond xbmc as well. No more stuttering. I achieved this by patching the kernel with rkpatchomatic-master tool using vsyncfixomatic script, which miraclously worked on this RK3066 kernel. My understaing was that it was only for the RK3188 kernels.
No VPN
hi guys thanks for the modded rom to allow root. i have tried private internet access on this but it will not work. i have tried to install TUN.KO installer to load the tun module which it does however when i try to run private internet access the box just reboots. i cannot run any vpn from it either subscribed or free, i have also tried open vpn to no avail, any suggestions?
There are currently 1832 users online. 0 members and 1832 guests.
